Results 1 to 6 of 6
    Jul 2012
    3
    Dell latitude D620 power problem
    Hi Fellas,
    I have a dell latitude d620 with some power problem, when i press the power button, the power led comes on for about 5secs and goes off again, no display, no activity, i have tried replacing the Ram and processor but still having the same problem, Can anyone help me with that
    Dallas, TX
    12,398
    Real common problems for laptops is that the power adapter breaks loose from the mobo...then it runs off the battery till it runs out..
    Do you know anyone with a similar machine that you could borrow their battery?
    “Nobody can go back and start a new beginning, but anyone can start today and make a new ending.”
    Jul 2012
    3
    i don't think so, i have tried every thing before, new adapter, new battery and still the same, other forums suggest it is the vga but i am not sure because when you plug in the adapter and press the power button the power led show for just five seconds and goes straight off.
    Jan 2003
    Outside the box
    8,489
    4
    Even if the GPU was faulty it should still stay powered on with the fans spinning and hard drive running. You just wouldn't see anything on the screen. It sounds like you've replaced just about everything imaginable. My only guess from there is that possibly the motherboard died.
    Prof. of DooGlian Studies MegalosSkylaki's Avatar
    Nr. GroundZero NYC
    8,031
    Just an idea, bluestone
    but if you are having so much trouble--and probably spending money on your Latitude D620 (I had one until I broke a hinge and opened the case) and the 12" version --until I shoted out the mainbord by spilling coffeee on the KB)--
    then consider buying what is probably a new one at Geeks.
    The models that dont have a letter like B or C after them are new or near new and come with a 90 day warrentee. Avoid the letter B or C.
    The latitude 630 is (near?) identical as far as I can see except the case is magnesium alloy.
    Geeks periodically sells the 620 and 630 at low $200.
    You would also have a spare battery and HDD and other parts from the purchase as you already own a D620
    Dell Latitude D620 Core 2 Duo T5500 1.66GHz 2GB 80GB DVD±RW Dell D620 Latitude D620
    Dell Latitude D630 Core 2 Duo T7100 1.8GHz 2GB 80GB DVD±RW Dell D630 Latitude D630
    MegalosSkylaki
    PS Sometimes the sell a 9-cell battery version.
    FIRST EIGHT YEARS ANNIVERSARY HONOR ROLL
    this April 18th, 2012 and will be Officially Celebrated That Day! SEE http://www.techimo.com/forum/imo-com...ml#post1070600
    Jul 2012
    3
    I have just the solution to the problem, and i have been able to solve it now. thanks to you all.....
  1. Dell Latitude D620 dim screen
    By wrhurd in forum Technical Support
    Last Post: October 16th, 2010, 02:18 AM
  2. Help Dell Latitude D610 Power Problem!!
    By kennjame622 in forum Technical Support
    Last Post: July 29th, 2010, 02:29 PM
  3. Dell Latitude D620 dim screen
    By AliOz in forum Technical Support
    Last Post: January 19th, 2010, 05:05 PM
  4. Dell latitude d620 printing to hp through time capsule
    By DavidH373 in forum Networking and Internet
    Last Post: September 29th, 2009, 06:38 AM
