Join TechIMO for Free!
Topic: When turning on the computer, the led's flash for a split second but it doesn't boot up or beep. The battery green light comes on. What could be the probable cause? Thanks Joe...
Currently Active Users: 1833
Discussions: 184,708, Posts: 2,205,624, Members: 227,430
Old September 14th, 2003, 02:51 AM   Digg it!   #1 (permalink)
Talking
IBM Thinkpad 390E No Power Up
jleach42 is offline   Reply With Quote
Old September 14th, 2003, 12:39 PM     #2 (permalink)
once=LUCK twice=GOOD
no1_vern's Avatar
Hi Jleach42,
Welcome to Techimo!
First I would make sure you are plugged into a working socket for the power. Next remove the battery and try to power on. If that doenst work put battery back in and Try pulling the plug, and power on again, does it react the same way as when plugged in?
Try replacing the board(bios) battery in the bottom of the TP.
If none of this works try removing the DIMM(memory) and reseating it.
Next reseat the CPU card. If all of these fail, I think you will have to take it in to IBM for repairs.
no1_vern is online now   Reply With Quote
Old September 14th, 2003, 05:18 PM     #3 (permalink)
Hi, This is Joe. No I don't have a battery for it, but when plugged in the green battery light comes on. I know the AD Adapter is good, because it powers my other Thinkpad. I have done the memory thing. But I will do the bios battery, never thought of that and if that doesn't work I'll try the cpu. Thanks. By the way if I leave the cpu out should it give me a beep code? Thanks Joe L.
Old September 14th, 2003, 10:58 PM     #4 (permalink)
no1_vern's Avatar
Yes I believe you will get a beep code, only the beep code you will get is that the processor is missing!
Old September 14th, 2003, 11:21 PM     #5 (permalink)
Thanks for your advice...Joe L.
Old April 11th, 2004, 01:23 PM     #6 (permalink)
I have this exact same problem on mine, and have tried both possible solutions with no results. Is there any other things to check. I have found that my 390e did boot like two times for me once, and it hasn't booted since. Maybe a loose connection? Does this computer need a hard drive to boot, because I dont have one in it right now. Thanks guys.
tblaketb is offline   Reply With Quote
Old May 11th, 2004, 01:04 PM     #7 (permalink)
If you are getting a blank screen, no monitor output, just the status lights, then reseat your memory. A memory stick that is not seated quite right will cause this problem. If it is almost seated right, it may boot sometimes, & not other times.
Be aware that a memory stick can look fully seated, but might not be. I had this problem, & it wasn't like the memory stick was hanging out there, but still, after reseating, life was good. Also trying cleaning the leads on the memory stick with an eraser. Make sure you are grounded to the chasis when you are working with these parts, you don't want to fry anything with static discharge.
If none of this works, try just completely removing one stick (if you have two memory sticks), it could be you have a bad memory stick. From there, it gets more complicated.
sleeperawaken is offline   Reply With Quote
Old May 11th, 2004, 11:49 PM     #8 (permalink)
thanks, I will try that.
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Password (8)
Is It Just Me? (13864)
John McFlIpFlOpPeR - for Bingo =) (50)
Building my first desktop (19)
Death of the Republican Philosophy (5)
Weirdest case ever... (13)
Problem With IDE Hard Drive (9)
Graphics Card for COD 4 (9)
so u cant crossfire with a HD 4850 .. (9)
Removing Safe Guard Easy (0)
dlp lamp crackling and popping .. (0)
Password (8)
need help hosting online (2)
Mozilla Firefox problem (7)
ATI RADEON 9800 PRO AGP power c.. (1)
FS: Microsoft Zune 30GB (1)
Javascript "carousel".. (1)
Xbox 360 games and Samsung Sync.. (2)
WTB: Nokia N95-4 8GB black (3)
