Thinkpad 770E Display Problem!!!
Currently Active Users: 2401
Discussions: 200,941, Posts: 2,379,279, Members: 246,304
Old September 16th, 2003, 12:11 AM   Digg it!   #1 (permalink)
I have a TP 770E and the display has a large black border around it... it's just not using the whole screen....
I know the screen phsically works because it uses the whole thing when I'm in the setup screen...
I already tried getting the latest drivers off the net and it the problem still resides....
any help would be much appreciated....
thanks
DGP
noise_watch is offline   Reply With Quote
Old September 16th, 2003, 03:41 PM     #2 (permalink)
Dudster's Avatar
Send a message via ICQ to Dudster Send a message via AIM to Dudster
What desktop resolution are you using? I'm guessing it's below 1024x768 which I believe is the resolution you need to use the whole of the screen. And unless it can go to 1280x1024, 1024x768 will probably be the highest resolution it can do. Oh and make sure you've installed the screen/monitor driver too (it's available on the Windows Supplement File disks if you haven't).
To change desktop resolution in Windows, right-click the desktop > choose Properties > Settings tab.
There's also an IBM Thinkpad utility (General Configuration Utility, I think) which can make it use the full screen at lower resolutions too.
770E drivers and utilities available here
Dudster is offline   Reply With Quote
Old September 16th, 2003, 09:00 PM     #3 (permalink)
bingo
thank you so much for your help
DGP
Is It Just Me? (2916)
Wireless Televisions. (9)
Regular Build (6)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
