Sony Vaio PCG-F270 LCD Screen help
Currently Active Users: 2682
Discussions: 200,966, Posts: 2,379,635, Members: 246,332
Old September 23rd, 2003, 12:12 AM   Digg it!   #1 (permalink)
Lightbulb
Any help is greatly appreciated!
Here is what I have:
The upper 1/8th of the LCD screen is working properly (you can see everything), the lower 7/8th of the screen is white (nothing on it, just plain white) :-(
I have been e-mailing with 2 repair guys both of them told me that the LCD screen needs to be replaced .
They quoted me between 170-270 for the replacement. (depending if I'll do it or send it in)
Now, a friend (electric engineer) told me that if I take it apart I can see who made the LCD screen (the manufacturer), and order it direct from the factory for around 60 bucks .... (taht is what he said ...)
The problem : I don't seem to find a way to take apart the screen : I can wedge a screwdriver in the side between the plastic, but it does not seem to "pop apart" or anything ...
So any of you guys knows how to look inside ? how to take out the LCD screen from the Laptop's plastic frame ?
thx!!
pageboy
pageboy is offline   Reply With Quote
Old September 23rd, 2003, 01:48 AM     #2 (permalink)
OK , I have found my answer reading some of the posts here : there were 4 tiny little screws hiding under the little rubber bumbers. Once I have removed those the front plastic panel came off fairly easy.
I have found the model # on the back of the LCD screen:
it is a Hitachi TX36D85VC1CAA size: 14.1 TFT resolution 1024x768 XGA
After a quick google search I have found a few suppliers, most of them do not list the price so I have e-mailed them for info. Also there are a few sites which list cross reference charts for finding out the model# of your laptop's screen WITHOUT taking it apart , hm ...
So this is where I am now, waiting for the pricing info to roll in ...I'll let you know about them ..
pageboy
Old September 24th, 2003, 10:32 PM     #3 (permalink)
well, some of the offers came in:
170
270
345
450 (this one is the manufacturer recommended service outfit)
(all in USD) .. I am still trying to find that 60 dolllar one .. anybody knows that source ???
pageboy
Is It Just Me? (3012)
Forty-six years ago today (7)
Internet Lost (5)
windows vista security holes (15)
Help getting around port 80 for camer.. (4)
Open With ..... Win7 (2)
Internet Lost (5)
virus blocking exe. files (1)
Nvidia GTX 260 problem (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
