Battery usage
Currently Active Users: 1797
Discussions: 200,505, Posts: 2,374,379, Members: 245,828
Old October 8th, 2003, 12:09 PM   Digg it!   #1 (permalink)
Battery usage
Hi everybody! I just got my first laptop , an IBM R40.
I m mostly using the laptop at home so far.So i was wondering since im always near a plug if i should take out the battery and use only the AC power.Is that appropriate or i should just continue to charge and discharge the battery?
thank you
iguana is offline   Reply With Quote
Old October 8th, 2003, 07:57 PM     #2 (permalink)
nuggettsmyname's Avatar
If you are always near a plug why wouldn't you just plug it in instead of using the battery?
It does not hurt it to leave the battery in the laptop while it's plugged in. I have heard IBM actually suggests this with some of their models.
nuggettsmyname is offline   Reply With Quote
Old October 9th, 2003, 10:18 PM     #3 (permalink)
This is interesting as there seems to be alot of different opinions. I remember when Nickel Cadium was the big thing, really the only thing; it was always suggested you remove the batteries/pack from the charger once complete. Otherwise the battery would start to discharge and it would ultimately shorten the life of the battery.
With Lithium Ion, most manufacturers suggest you leave the device on the charger unless you need to take it off. LIO is much more advanced and the charging system can power off once the battery is fully charged. Also, one of the supposed advantages of LIO is that you can charge the battery without doing a full discharge. I doubt this somewhat as I've had cell phone batteries die prematurely from what I felt was constant charging w/o discharging fully.
Personally, I leave my home laptops on the charger while using them and only take them off when I switch rooms. The only thing that I've noticed is that when I don't use them for a day or two, I find that the battery is at about 85% when I take it off the charger. That's simply because once the battery is charged, the charger powers down, and the battery goes through its natural discharge.
Big Calhoun is offline   Reply With Quote
Old October 10th, 2003, 12:16 AM     #4 (permalink)
This is correct. The deeper you dischare a LiIon battery the worse the performance gets.
Is It Just Me? (1633)
FT HOOD attack: 7 killed 12 injured (64)
HELP!!! What do you think of this s.. (15)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Need Assistance Overclocking and Ra.. (14)
New Processor, Monitor will not turn .. (1)
HELP!!! What do you think of this sys.. (15)
FAT32 to NTFS file system in Win2kpro (2)
2009 Build (4)
Review My Build (2)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
Motherboards and my curse... (24)
Mic won't work. (2)
