Toshiba Satellite 1800-400 doesn't power on
Currently Active Users: 1700
Discussions: 200,933, Posts: 2,379,193, Members: 246,298
Old October 29th, 2003, 11:05 AM   Digg it!   #1 (permalink)
Unhappy
Hi
my toshiba doesn't power on, the green led indicates power on but hardrive doesn't start (checked the hardrive and is ok), can't even open cd-rom drive. don't know what to do, looks lokie the motherboard is faulty but i'm not sure. any ideas what is wrong?
sprocket is offline   Reply With Quote
Old October 30th, 2003, 08:57 AM     #2 (permalink)
hickory's Avatar
warranty?
Is it still under warranty? If so I'd give Toshiba a call first.
hickory is offline   Reply With Quote
Old November 8th, 2003, 07:19 PM     #3 (permalink)
no its not under warranty
Old November 9th, 2003, 09:16 PM     #4 (permalink)
bad power supply
it,s on the mb.
tech56 is offline   Reply With Quote
Old November 9th, 2003, 09:50 PM     #5 (permalink)
MDS
Never forget
MDS's Avatar
are you running on battery or the power pack ? or does it act the same both ways?
MDS is offline   Reply With Quote
Old November 12th, 2003, 09:19 AM     #6 (permalink)
act the same on battery and power pack. need some tech desc for mb then, don't even know the model but it's running on athlon 800 mhz. thanks guys
Old November 12th, 2003, 02:40 PM     #7 (permalink)
aldtech's Avatar
Are the lights flashing? If so and it is in a pattern then that is an error code. In my experiance as a certified Toshiba tech, flash codes are almost always the system board.
If you can post the model number, that is the second number on the back label (it might say part number) I wioll try to look up part numbers for you.
AL
aldtech is offline   Reply With Quote
Old November 13th, 2003, 10:05 PM     #8 (permalink)
no, they're not. model no. is PS181E-00D59-EN
Old November 21st, 2003, 12:06 PM     #9 (permalink)
help
AL
can't find power suppply on mb, need some more help, maybe i can fix it myself, tried to find some tech descr but nothing, where is power supply? where is model number on mb?
Is It Just Me? (2884)
Wireless Televisions. (5)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
