Join TechIMO for Free!
Topic: i have an ibm thinkpad laptop, that will not come out of hibernation mode. It is running win 98. The problem occured when I was networked to desktop using xp. The transfer of files went well then everything went downhil...
Thread Tools
Currently Active Users: 2295
Discussions: 186,626, Posts: 2,223,851, Members: 229,762
Old November 21st, 2003, 09:58 PM   Digg it!   #1 (permalink)
ibm thinkpad hibernation problem
i have an ibm thinkpad laptop, that will not come out of hibernation mode. It is running win 98. The problem occured when I was networked to desktop using xp. The transfer of files went well then everything went downhill. The laptop locked up. I have goback installed on laptop and thought i would just goback before the installation of pcmia network card and software and some files xp wanted me to install on 98 (laptop) When i power cycled the laptop goback started and then froze in mid boot. When i powercycled again nothing happened. When power is applied the laptop goes straight to hibernation mode. Tried everything i can think of any help would be greatly appreciated...........
drowe4 is offline   Reply With Quote
Old November 24th, 2003, 12:32 PM     #2 (permalink)
Arrow
i had an ibm a30 thinkpad with win 98 and had hibernation problems also. i never had the problem you described but if i would leave my laptop for some time it would go into hibernation which is what it is supposed to do but i could never get it out of hibernation. i found that you can bring it out of hibernation by pressing the fn hot key and then pressing the escape key. you have to give it a couple seconds cause it wont come out of hibernation right away. i never liked that hibernation mode myself so what i did was go into the bios and disable it. if you disable it you should not have any more problems i think, like i said i never had my laptop hibernate during boot mode but win 98 is much more finicky about hibernation modes. i upgraded my a-30 to win xp pro and it ran much smoother than 98. i hope this info helps, if you have any more problems just reply to your thread.
whiteashcm1 is offline   Reply With Quote
Old November 24th, 2003, 01:46 PM     #3 (permalink)
did you copy some win xp files to your laptop with win98?
Old November 24th, 2003, 01:57 PM     #4 (permalink)
Jack Hannibal's Avatar
I came across a similar issue before. I found out it is believed to be a glitch with an overcharged capacitor inside the unit on the T series laptop. To remedy the problem, first remove any batteries (i.e., the internal battery and the Ultrabay battery, if installed) from the unit. Next, you need to drain any remaining charge from the capacitor: With the batteries removed, hold the power button down for at least 90 seconds. The overcharge should completely drain, and you can then reconnect the batteries or AC power and turn on the unit. I have not actually tried this myself. Hopefully your results will be positive.
Jack Hannibal is offline   Reply With Quote
Old November 24th, 2003, 03:24 PM     #5 (permalink)
hickory's Avatar
thats what worked for me
I had the same problem and when I called IBM support thats exactly what she had me do. I think what Jack Hannibal said is a good place to start!
hickory is offline   Reply With Quote
Old August 25th, 2008, 09:33 AM     #6 (permalink)
Smile
IBM Thinkpad T43
"To remedy the problem, first remove any batteries (i.e., the internal battery and the Ultrabay battery, if installed) from the unit. Next, you need to drain any remaining charge from the capacitor: With the batteries removed, hold the power button down for at least 90 seconds. The overcharge should completely drain, and you can then reconnect the batteries or AC power and turn on the unit. "
This suggestion works. I had the above problem with my IBM ThinkPad T43 after it went into hibernation one day. We did exactly that...removed the battery, removed the AC Power, held the power button in for several seconds, then replaced everything & it booted fine.
PammiePi is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
The F word (under-utilized or horri.. (12)
Is It Just Me? (16936)
WHOIS info (6)
Folderchat Weekday thread (372)
Super folding (14)
Popular Online Pc Retailers (12)
Official World of Warcraft Thread!! (4506)
Wireless Connectivity (6)
PSU recommendation, think mines is .. (14)
VLAN on DLink DES-3226S (23)
Samsung launches 256GB SSD (2)
How can I make Dial Up faster? (8)
How do I find the volume label .. (5)
AM2+/AM3 (3)
How to create watermarks in gim.. (3)
Official World of Warcraft Thre.. (4506)
Various items for sale (1)
Woot-off (5)
9800GTX 512meg (8)
