Thread: Over the Ear Head Set
April 7th, 2004, 06:23 PM #1
Hello All,
I am looking for an over the ear headset fro my computer
wireless would be nice, but not neccassary
Here is the kicker, I am trying for the cheapest possible, have to get approval!
Any Ideas??
Salesman_GilImagination, is more important then knowledge... Except this time....
April 7th, 2004, 09:52 PM #2Member
- Oct 2003
- 43
Hmm... by over the ear headset do you mean -->
If so get the ones in that picture.
They're GE brand X Bass headphones.
I have them and they're only $20 and i got them at target.
They have great sound and it even comes with a little remote to control vibration with bass which is just awesome.Last edited by OuTrAgE; April 7th, 2004 at 10:01 PM.
April 7th, 2004, 11:29 PM #3
I'd recommend the Sennheiser HD 437/457s. They sound excellent, and aren't sealed cup phones, which means sound will leak in and out. I don't know if that's a plus or a minus for you. I paid $30 for them at www.newegg.com
April 8th, 2004, 08:50 AM #4
Over the Ear- a one piece headset that fits over just one ear, and has a mic coming off it. There is no band over the head or around the back of the head. It kind of clips on. You tend to see them for cell phones, but I'm looking for one fro a PC.
April 8th, 2004, 09:18 AM #5
I'd guess you're talking about this.
http://www.newegg.com/app/ViewProduc...106-404&depa=0
or
http://www.newegg.com/app/ViewProduc...106-332&depa=0
April 8th, 2004, 08:36 PM #6
I know koss makes some good clip-on headsets similar to the KSC-50 and KSC-35.
The two cards should both use the same driver install. With Afterburner, I know it will work on the non-MSI card as individually installed with no manufacturer lockout, but I don't know if it...
New Pc
