Speaker Help
Currently Active Users: 1528
Discussions: 200,952, Posts: 2,379,478, Members: 246,322
Old June 7th, 2004, 01:59 PM   Digg it!   #1 (permalink)
Speaker Help
I already have some Zalman surround-sound 5.1 headphones. But I have a 6.1 sound card and decided to get some real speakers. Are there any speakers out there that can function as 7.1 and 6.1 so they will work if I decide to upgrade my sound card.
So what speakers should i take a look at? I have a lot of Logitech products and have never had any problems with them, so I
m thinking about getting some Logitech ones.
Rand Dusing is offline   Reply With Quote
Old June 7th, 2004, 02:31 PM     #2 (permalink)
Onii-san
Bizkitkid2001's Avatar
Well for one, logitech doesn't have a 7.1 configuration. But then again, you don't need 7.1. To me, there isn't really any advantages a 7.1 system has over a 5.1 system. SO keep your current 5.1 sound card, and go out and buy some kick ass 5.1 speakers. You will be more than happy with either the Logitech Z680s or the Klipsche 5.1 Ultras.
Bizkitkid2001 is offline   Reply With Quote
Old June 7th, 2004, 04:13 PM     #3 (permalink)
Well actually I have a 6.1 sounds card, they just dont have 6.1 speakers.
I guess i'll take a look at those. But if I have 6.1 should I just get 6.1 speakers?
Old June 7th, 2004, 04:18 PM     #4 (permalink)
Onii-san
I think a 6.1 card can do 5.1.
Old June 7th, 2004, 04:20 PM     #5 (permalink)
Yah, a 6.1 can do 5.1. But I was asking, if I have 6.1 sound card, should I might as well get 6.1 speakers?
Old June 7th, 2004, 05:27 PM     #6 (permalink)
Send a message via AIM to matthewd
Get the 5.1 speaker system. klipsch 5.1 ultra or logitech 680 are the best right now. If your on a budget get the logitech 5300 5.1, it is an incredible steal for the price. Your sound card will support 5.1 just the same as 6.1 so I wouldn't spend the extra money for an extra speaker cause you won't notice the difference.
Matt
matthewd is offline   Reply With Quote
Old June 7th, 2004, 07:44 PM     #7 (permalink)
pinipig523's Avatar
stay with 5.1 - u dont need 6.1 as not many games or movies support 6.1.
do not confuse 6.1 as being of higher quality or better sounding than 5.1 speakers. a good 5.1 set like the 680s or the ultras are a far better deal than anything 6.1 out there - save the megaworks.
if u really want something 7.1 - go for the gigaworks... those would be fine.
pinipig523 is offline   Reply With Quote
Old June 7th, 2004, 11:48 PM     #8 (permalink)
Ok, Now I just better start loooking at the Fry's ads and NewEgg.com. Thanks for all the feedback guys.
Old June 11th, 2004, 01:33 AM     #9 (permalink)
Wow, Just took a look at those speakers and I never knew they were so expensive. I was thinking along the lines of 100-150 bucks.
Old June 11th, 2004, 01:45 AM     #10 (permalink)
nuisance since 1968
OuTpaTienT's Avatar
That won't even get you a great 2.1 system (unless you're a prudent shopper).
OuTpaTienT is offline   Reply With Quote
Logitech z680 problems MartyWilliams Multimedia and Audio 6 November 11th, 2003 02:44 AM
Audigy! Dave Goodmen Multimedia and Audio 5 May 9th, 2003 07:32 PM
Speaker wires. Mr. Fingers Multimedia and Audio 1 August 17th, 2002 04:14 PM
pc to stereo connection? S.D.Willie Multimedia and Audio 6 February 19th, 2002 10:15 PM
Is It Just Me? (2943)
Print spooler problem (15)
SELLING FRESH,CVV,LOGINS,DUMPS,TRACKS.. (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
