no audio device???
Currently Active Users: 1463
Discussions: 200,927, Posts: 2,379,134, Members: 246,293
Old August 22nd, 2004, 12:17 PM     #11 (permalink)
ive dowloaded the file, how do i install it??
WAKKA2223 is offline   Reply With Quote
Old August 22nd, 2004, 12:19 PM     #12 (permalink)
no i seriously doubt it! i had the pc wiped b4 i installed win xp pro
Old August 22nd, 2004, 12:26 PM     #13 (permalink)
Best To Avoid Me
Martoch's Avatar
I'll have to download the file to find out for sure...but normally you would unzip the files to a specific folder (of your choice), then either run a setup.exe file or go back into your device manager, right click on your audio hardware with the yello !, click update driver, and point toward that folder. Sorry I'm typing this qiuckly as I'm on the phone now.
Martoch is offline   Reply With Quote
Old August 22nd, 2004, 12:26 PM     #14 (permalink)
ha ha, neva mind all sorted now, thanks Martoch!!!
Dell Dimensions 4600 Sound problem whannanna Multimedia and Audio 2 July 11th, 2004 06:25 PM
audio drivers presence06 Multimedia and Audio 3 May 31st, 2004 02:09 AM
AC97 onewave4me Multimedia and Audio 8 October 13th, 2003 11:54 PM
audio won't work on motherboard hgrad Technical Support 11 July 24th, 2003 02:12 PM
No Playback Devices ! UncleGus Technical Support 7 March 30th, 2003 06:32 AM
Is It Just Me? (2866)
Obama the Muslim (14)
Safe International POS for CC,DC cash.. (0)
Fire in DVD (1)
Regular Build (0)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
