no audio device???
Currently Active Users: 1880
Discussions: 200,911, Posts: 2,378,951, Members: 246,279
Old August 22nd, 2004, 11:59 AM   Digg it!   #1 (permalink)
no audio device???
hi,
jus installed windows xp pro into my pc. But when i went to run it there was no sound, so i went into my control panel to check it out and it seys there is 'no audio device detected'???? can anyone help please?
also when i try to install my games it tells me theres not enough space when there is??
WAKKA2223 is offline   Reply With Quote
Old August 22nd, 2004, 12:01 PM     #2 (permalink)
Best To Avoid Me
Martoch's Avatar
Check your device manager for any yellow exclamation points indicating problems with your hardware...most likely just a few missing drivers.
Right Click My Computer--Properties--Hardware Tab--Device Manager Button.
What are your hardware specs?
Martoch is offline   Reply With Quote
Old August 22nd, 2004, 12:02 PM     #3 (permalink)
where can i get these drivers from??
Old August 22nd, 2004, 12:03 PM     #4 (permalink)
imperial-g motherboard
1gb pc 2100 memory
p4 2.4
ati radeon 9800 pro (128bit)
80 gb hard drive
Old August 22nd, 2004, 12:06 PM     #5 (permalink)
yeh theres yellow ! on muiltimedia audio controller and sm bus controller...
Old August 22nd, 2004, 12:08 PM     #6 (permalink)
Best To Avoid Me
Martoch's Avatar
Hang on, I just got my coffee and need to do a little research. Didn't your motherboard come with driver disc?
Old August 22nd, 2004, 12:10 PM     #7 (permalink)
yeh kinda lost it! doh! i know....
Old August 22nd, 2004, 12:11 PM     #8 (permalink)
Best To Avoid Me
Martoch's Avatar
http://www.e4allinc.info/dir1/mother..._downloads.htm
Scroll down to Advance Logic AC'97 Audio Drivers
Old August 22nd, 2004, 12:15 PM     #9 (permalink)
its downloadin now thx...
i guess u dunno y i dnt seem to have any space for my games do u?
Old August 22nd, 2004, 12:17 PM     #10 (permalink)
Best To Avoid Me
Martoch's Avatar
Well I'm not a mind reader, but we can examine that issue if you'd like...so you're entire 80gb drive is filled?
Dell Dimensions 4600 Sound problem whannanna Multimedia and Audio 2 July 11th, 2004 06:25 PM
audio drivers presence06 Multimedia and Audio 3 May 31st, 2004 02:09 AM
AC97 onewave4me Multimedia and Audio 8 October 13th, 2003 11:54 PM
audio won't work on motherboard hgrad Technical Support 11 July 24th, 2003 02:12 PM
No Playback Devices ! UncleGus Technical Support 7 March 30th, 2003 06:32 AM
Why is Khalid Sheikh Mohammed even .. (7)
Is It Just Me? (2820)
Foreign voltage (7)
Print spooler problem (8)
EVGA 9800 gtx help with finding a g.. (7)
PSP Go bought in Japan (0)
Foreign voltage (7)
Asus P4G8X Mobo (3)
windows vista security holes (2)
World's largest Monopoly Game using G.. (329)
EVGA 9800 gtx help with finding a goo.. (7)
Need hard disk drivers (4)
Boot Problem? (0)
Logitech G9 laser gaming mouse $59.95.. (2)
$5 off any item with the purchase of .. (1)
hybernate option (2)
