Page 1 of 2 1 2 LastLast
Results 1 to 20 of 25
    Ultimate Member pinipig523's Avatar
    Aug 2003
    ChiTown, IL
    1,320
    High-end Headphones Needed! Help me!
    Ok... as some of you know, I consider myself an audiophile and I know what sounds good and what doesnt. My computer speakers is proof of that (and a bit of my overzealous crazy side as well) . So anyway, is there any way I can top my speakers with a good headset?
    Current PC System:
    4xPolk LSi7 Bookshelves ($1400)
    1xSVS 25-31PC+ subwoofer ($800)
    Harman Kardon AVR-330 Receiver ($600)
    I am looking at various headphones but I cant decide... and it seems to be a lot harder to audition them (I cant walk in a Tweeter Audio Shop and take a listen). Which models should I look out for?
    Sennheiser?
    Grado?
    Help me out please!
    Oh and by the way, do I need a separate amp for it or will my HK 330 be able to power it just fine?
    Ultimate Member shawshank62's Avatar
    Oct 2002
    southampton, pa
    4,789
    Generally sennheiser has the best pc headphones, these are a bit pricey but im sure they are well worht the money.
    http://www.newegg.com/app/ViewProduc...106-392&depa=0
    Good review on the HD 555's
    http://www.dansdata.com/hd555.htm
    Senior Member jagnorm's Avatar
    May 2003
    Maryville TN
    511
    sennheiser are exellent head sets. You can find great quality headphones at music store.
    Some of the best head sets are used for recording studios.
    Guitar Center is just an example of a place to find quality headphones.
    Aug 2003
    ChiTown, IL
    1,320
    Whats the difference between open and closed headphones?
    Does open sound more spacious - kind of like when you're listening to actual speakers?
    I assume closed is preferred if I dont want to bother others?
    I was looking at the Senn 280 or the Grado SR125 (although the RS2 by Grado looks mighty tempting - I just dont like the awkward headband styling). Any other brands?
    Keep the suggestions coming! THanks!
    Onii-san Bizkitkid2001's Avatar
    Sep 2002
    San Antonio
    10,933
    Sennheiser HD 600, if you can afford it.
    These are the best sounding headphones I have ever heard.
    Sep 2002
    San Antonio
    10,933
    Here is a comparirions between sennheiser's and grado's top headphones.
    http://www.audiorevolution.com/equip/sennheiserphones/
    BBA
    BBA is offline
    Ultimately BBA BBA's Avatar
    Jax, Fl
    5,048
    The best headphones for gaming or for movies are the Sony surround IR cordless with head tracking. It will set you back about $700 if you search deals on the web.
    Sound Advice usually has a pair you can demo.
    HERE
    BBA
    Sep 2002
    San Antonio
    10,933
    It uses infrared? uck, that means if anything gets between the headphones and the recieve (Person walks by, cat jumps in the air, etc..) you will lose the signal.
    Ultimate Member MD1032's Avatar
    Nov 2002
    1,724
    Go for the Grado SR-225's if you can afford the jump. It'll save you the upgrading later. Plus, they're the best rock phones out there. If you want closed, I would grab a pair of Audio Technica A900's.
    The HD555's and 280's also also fine reccommendations, though I don't exactly know how much you'd like the 280's. Seems like half of Head-Fi likes em, half hate em.
    Oct 2004
    25
    either senheiser or AKG mate but if u can afford it go with the Bose avionics approved external noise silenser hp's
    Aug 2003
    ChiTown, IL
    1,320
    Thanks for all the tips guys. However, I think its time to set some budgetting.
    Obviously, $700 for a pair of heads is too much for me.... wow.... lol.
    How about this:
    Give me your best suggestion for EACH of these 3 price ranges:
    $300
    $200
    $100
    Nothing over $300, and nothing really under $50.
    I want you guys to throw out some heads that you guys think I should look at... thanks again.
    Sep 2002
    San Antonio
    10,933
    Then I will have to say the Sennheiser HD 595 for the $300 range.
    http://www.sennheiserusa.com/newsite...ransid=newHD-3
    Do you have a B Jorn's or any other pro audio shops around your area? Going out and listening to the headphones yourself is your best bet.
    Aug 2003
    ChiTown, IL
    1,320
    Thanks for the tip Biz... 595 for $300. Any other ones you can think of for the 200 and 100 category?
    MD - chime in too. I know you know quite a bit about heads.
    Any and everyone else.... keep 'em coming. =)
    Ultimate Member Tomteriffic's Avatar
    Ohio (transplanted f
    3,118
    Quote Originally Posted by pinipig523
    Worth auditioning in the $100 ballpark: Senn 280's, Sony MDR 7506's or as much Grado as $100 will buy.
  15. #15
    Sep 2002
    San Antonio
    10,933
    Quote Originally Posted by Tomteriffic
    For grados in the $100 area my choice would be the SR 80s.
  16. #16
    Aug 2003
    ChiTown, IL
    1,320
    Alright... looking into the tips.
    Any other suggestions for the 200$ category?
  17. #17
    Ultimate Member crazyray's Avatar
    1,228
    Lightbulb
    Just a reminder....speakers and headphones both fall into a special category that requires that YOU listen to them and decide how you like what you hear. Further, headphones have a critical comfort factor. It doesn't matter how good they sound if you can't stand them sitting on your head!
    My vote goes for Sennheiser 600's.
  18. #18
    BBA
    BBA is offline
    Jax, Fl
    5,048
    I would say for the $200-$300 you need to look at the Bose noise cancelling...I used a set at QUakecon this year and let me tell you...beats the hell out of any other headphone I have owned.
    I can tell you the Grado is the most uncomfortable headphone ever made for the first 6 months of wear...they have to break in to your head shape and by then, you are used to them so you dont notice the discomfort anymore.
    As for Sennheiser...I wouldnt recommend them myself, but I have a little more discerning ear than most. To me Sennheisers sound dull and flat, not crisp, transient or clean. As was said above, you have to audition them yourself or expect not to be happy.
    Looks like you need to visit some high end audio stores. (just tell them you have klispchhorns and Macintosh amps, they will bend over backwards to try to sell you something)
    BBA
  19. #19
    Aug 2003
    ChiTown, IL
    1,320
    LOL to that klipschorn/macintosh idea!! I should do that!
  20. #20
    Aug 2003
    ChiTown, IL
    1,320
    I was just wondering.... what do you guys think of the higher end sony heads? I.E. the 600 and the 700 series?
  1. How much did your sound setup cost?
    By ShawnD1 in forum IMO Community
    Last Post: August 11th, 2004, 01:56 AM
  2. Sony MDR V700DJ
    By ClubMed in forum Multimedia and Audio
    Last Post: January 24th, 2004, 09:41 PM
  3. Headphones vs speakers?
    By M3thod_Man in forum Multimedia and Audio
    Last Post: January 20th, 2004, 02:36 AM
  4. Soundcard line out to switching box
    By Dudster in forum Multimedia and Audio
    Last Post: June 9th, 2003, 02:13 PM
  5. Grado SR80 headphones
    By SpookyEddy in forum Multimedia and Audio
    Last Post: February 20th, 2003, 08:36 PM
