Thread: codec
October 25th, 2004, 10:21 PM #1
codec
hey guys
i have a problem playing an .avi file on my computer, none of my players won't play it, power dvd just does nothing and win media player says that it cannot play the file because it might not support the file type (which i doubt since it's avi) or might not support the codec that was used to compress the file. well that i understand but my question is: is there a way to find out WHICH codec was actually used? i have quite a few in my computer but have no idea which one i need for this file to play as neither of the players actually says which codec is needed. also i have another .avi file which plays fine with power dvd but when i try to play it in win media player i get the same error message about the codec again. does anyone know why? i don't get it...
thanx for help
October 25th, 2004, 10:26 PM #2
vcdhelp.com
loads of help there. i think you might need divx player or at least the coded bundle that comes with it. that will allow you to play most avi files. also, i wish i could remeber, but i know there is a program that will tell you what codec the video file was made with. that would certainly help if you could find itwhat? like a blue spider? get it off!
http://live.xbox.com/member/BMF Yohon
October 25th, 2004, 10:28 PM #3
thanx, i'll try the link, about the divx i actually have the player and the bundle but still no luck with this file...
October 25th, 2004, 10:32 PM #4
DIVX player with a KazaaLite Megacodec installed handles most of what I throw at it.
Millions long for immortality who don't know what to do with themselves on a rainy Sunday afternoon.
Susan Ertz
October 25th, 2004, 10:40 PM #5
i found something called afreeCodecVT which should help with identifying the codec but the comments say that it has some issues with norton, has anyone tried this soft?
Inappropriate codec removal
By muno in forum Multimedia and AudioReplies: 6Last Post: January 26th, 2004, 08:26 AM -
WMP 7.1 won't play full screen
By macko in forum Applications and Operating SystemsReplies: 5Last Post: December 13th, 2002, 09:29 AM -
avi-files
By jasschenk in forum Technical SupportReplies: 5Last Post: November 8th, 2002, 04:51 AM -
AVI - No sound.
By tobu in forum Technical SupportReplies: 3Last Post: October 29th, 2002, 05:44 AM -
KaZaA (LiTe) Search Problem
By I Dunno NEthing in forum General Tech DiscussionReplies: 15Last Post: July 9th, 2002, 01:11 AM
Hi, Are you ready to start enjoy of your weekend with amazing shows and movies:
My fav shows and movis
