Thread: DVD R formats
January 12th, 2005, 08:27 PM #1
DVD R formats
K, which format is used for Movies, data?
ex: DVD+R, DVD-RW ect
I just wanna know which is more compatile for dvd players? and the specific applications for all of them-Space
January 12th, 2005, 08:49 PM #2
Both work. But -R is most compatable with dvd players. -RW is less cause of the RW capability. The +R will work on older sonys I have but not some of the newer off brand ones will play them. So thats iffy. (sony made +R I think).
Bottem line dvd-r best for standalone dvd players and overall compatability.
DVD+RW best for data and re-recording alot. So pc backups and stuff go for +rw everytime. The + has a extra ring that stores what is on the disc. Like crc check. And thus takes mroe to damage the disc to where cant be read. A standard +RW is 10x better at retaining data then a old cd-r was. Even though the pits are soo much smaller (or dots in this case). Hope that helped.
January 12th, 2005, 09:18 PM #3
I read somewhere that the +R was capable of utilizing "bit setting" if your burner has this capability. This allows you to record a dvd and make it appear to a set top dvd player as a dvd-rom disk. This increases the compatibility with set top players.
Benjamin Franklin
January 12th, 2005, 09:21 PM #4Are you sure its +R? I thought it was +RW (or -RW). I know lite-on has an app that will change the bit setting for lite-on drives.
Originally Posted by elroy
DVD Media.........
By Network67 in forum Multimedia and AudioReplies: 5Last Post: October 2nd, 2004, 04:58 PM -
Lite on DVD Burner.
By Darthgary in forum Storage RelatedReplies: 28Last Post: November 11th, 2003, 02:11 AM -
good dvd burner ?
By ZL1 in forum General Tech DiscussionReplies: 20Last Post: August 17th, 2003, 04:21 AM -
Problems with Nero
By melkot in forum Technical SupportReplies: 6Last Post: September 9th, 2002, 06:18 PM
This is the picture posted on my refrigerator at home:
