Page 1 of 2 1 2 LastLast
Results 1 to 20 of 32
Thread: DVD burning
    Sep 2003
    West Lafayette, IN
    293
    DVD burning
    Hi
    I dl'ed some tv shows and I would like to burn them into a dvd. Each is 700mb so roughly 6 files would fit in a 4.7gb dvd. The format of the media is avi. Is there a simple way to encode it and burn them into the dvd? Thanks.
    Sep 2003
    West Lafayette, IN
    293
    hello?
    I think you should answer my question, because I did a search and I havn't found the answer.
    I tried encoding the 700mb (1h 18min) files, but they are each ~4gb. How can i fit 6 episodes (700 each) into one dvd-r disc.
    Moderator phenious's Avatar
    Winter Park FL
    5,323
    Normally the TV shows that you download are in a compressed format that use the AVI Container. xVid and DivX are popular. I have seen a few tools like Virtual dub which will let you re convert the videos back to Mpeg2 DVD format for burning. Can anyone input on the legality of downloading TV Shows? I think it is legal but I am not sure.
    Perfetc Member VHockey86's Avatar
    Jan 2003
    Maryland Suburbia
    4,334
    virtualdub can only create AVIs... not mpeg.
    You'd need something like TMPGEnc for that.
    Winter Park FL
    5,323
    OK so Virtual Dub -> *.avi -> TMPGenc -> *.mpeg
    I could have swore I have seen tools that do all of those steps for you but they want $29.99 to do it.
    Ultimate Member Xtreeme's Avatar
    Apr 2003
    PA. USA
    3,310
    Quote Originally Posted by minduka
    Hi
    Yep buy nero. You can try the fully functional demo for 30 days. Try before you buy is the best. Go to http://www.nero.com/us/index.html
    Especially since it sound like youve never done this stuff. Nero is very user friendly and you will get a great quality dvd in the end. Its all I use.
    Apr 2003
    PA. USA
    3,310
    Quote Originally Posted by VHockey86
    TMPGEnc is great results but SLOW compaired to most mpeg encoders out there now. At its time of release it was #1. I even have the adobe premiere pro package with it. Just slower and harder to use then nero for a quick movie. Now adobie premiere does ALOT more detailed editing but thats for the more serious user willing to get there hands dirty.
    http://www.adobe.com/products/premiere/main.html
    Jan 2003
    Milwaukee, WI
    7,657
    Are you asking this so that the format can be seen and correctly read by a standalone DVD player hooked up to your TV?
    Sep 2003
    West Lafayette, IN
    293
    Quote Originally Posted by JPMiller
    Yes. Is it possible to put 6 episodes each 700mb? (~1h18m) I tried encoding with TMPGenc, but each file is ~4.1gb.
    codec: divx3 low
    resolution: 576x432
    aspect ratio:4/3
    frame rate:23.976
    Apr 2003
    PA. USA
    3,310
    Did you try nero. Thats exactly what it does. Lets you take several movies and combine into one. Then creates menus and all kindsa stuff to go with. Just follow the wizard.
    Aug 2004
    Joplin, MO
    414
    You need DVD Shrink.
    The files you download are encoded with DivX to make the file size smaller. When you convert back to .mpeg or .vob the file size goes back up. That is why they won't fit. So, after you have converted your file to mpeg with TMPGenc, you open them with DVD Shrink and make them the file size you want. However, picture quality will take a beating.
    Sep 2003
    West Lafayette, IN
    293
    If I used DVD shrink to change the size. How bad will the picture quality decrease? I don't mind if it's not DVD quality. Would it look bad on a 32in TV?
    I havn't tried nero yet, since I havn't had the time. So does nero encode it to mpge format and change the file size? Sorry if that's what your answer means, I just want to make sure.
    practically canada. bombledmonk's Avatar
    Aug 2003
    MN
    3,384
    Nero 6 will convert and burn for you in one step as long as you are able to watch the .avi on your computer.
    And you will not fit 6- 78min shows on a DVD. You'll be lucky to get respectable quality with 2 or 3.
    Sep 2003
    West Lafayette, IN
    293
    If I just want to watch them on a computer, then could i just burn them as data files and fit 6 episodes?
  15. #15
    Member phecky's Avatar
    Jan 2002
    Leesburg, Va.
    182
    DVD Shrink won't open avi or mpeg they have to be in the VOB format with separate folders for vid and sound. For VHS tapes I've had to record 1st then burn to HD. In my case I'm using WinDVD creator to make movie (burn) from the corresponding mpeg file. DVD shrink's main attribute seems to be working with existing dvd structures. I haven't found a simple conversion tool for mpeg to vob. It probebly doesn't exist because I'm finding out it's not a simple process. However, I am having a good success rate converting my vhs collection- just takes time.
    The World needs to change from revolutionary thinking to evolutionary.
    Barton 2500+
    1 gig corsair
    ATI 9800 Pro
    VIA kt600
  16. #16
    Mar 2002
    1,511
    For ease of use, I'd say use NERO's build in movie making app. It is simple to use, and bottom line is.. it works.
    Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime.
  17. #17
    Aug 2003
    Gateshead U.K.
    11,422
    yes
  18. #18
    Aug 2003
    MN
    3,384
    Yes, you can just burn the files and you will be able to watch them on your computer or a DivX enabled DVD player(which most people don't have)
  19. #19
    Sep 2003
    West Lafayette, IN
    293
    Thanks guys!
  20. #20
    Member twendanewhite's Avatar
    Nov 2004
    Queens, NY
    343
    When burning DVD discs with Nero should i select to burn a "DVD-ROM(ISO) or a DVD-Video" ?
  1. NEC DVD Burner not recognized
    By TheWildMan2000 in forum General Tech Discussion
    Last Post: September 15th, 2004, 11:48 PM
  2. DVD burning - What rate do to capture the video at?
    By kruseman in forum Multimedia and Audio
    Last Post: May 16th, 2004, 12:05 PM
  3. dvd burning
    By jml90 in forum Applications and Operating Systems
    Last Post: March 1st, 2004, 04:08 PM
  4. DVD burn...no audio?
    By nerdgirl in forum Multimedia and Audio
    Last Post: November 11th, 2003, 01:16 PM
  5. DVD-RW Question...
    By Martoch in forum Multimedia and Audio
    Last Post: August 5th, 2002, 06:39 PM
