Results 1 to 6 of 6
    Dec 2003
    77
    Creative CT4810 Vs. ES1370
    hi ppl !!!
    i have those 2 sound cards and both are working ...
    from research i found out that they both based on the ENSONIQ chipset
    can anyone tell me which one is better/newer ?
    10x in-advance
    CRAP! Brainchild's Avatar
    Monett Missouri
    4,341
    CT4810 is the PCI 128,I would use it.The 1370 is a AWE 64 I believe.I got the 1370 I had to run on hte 128 drivers but didn't function right,Don't remember why,but the AWE 64 drivers worked great.I had a lot of problems getting the 1370 working right.I finally phased it out
    I just bought a SB Live card,and running on WinXP it blows these other cards out of the water.Something to think about
    Check out my band Saving Silence
    Ultimate Member Xtreeme's Avatar
    Apr 2003
    PA. USA
    3,310
    Well, they are both cpu driven sound cards. LOL. Big spike in cpu usage pluss less sounds handle per moment. A MCP-T mobo (nforce2 sound) or SB will whip it bad. I have both of those. MCP-T and SB live MP3+. Plus I have the AWE 64 made by Aopen its the "cobra" model with 4 ch sound. No doubt the other cards own it. I just dont care for SB bad driver support. If it works GREAT stuff. When it doesnt-dont expect a lick of help from them nor a fix EVER. They never fixed the !850 chipset sound bug to this day. From what over 3 years ago I had that board. Pathetic. I ahd to dw a hacked version of the sound drivers one file to get it to make any sound at all. lol.
    Monett Missouri
    4,341
    I just used the driver XP installed for hte LIVE card,and it works great.Don't knowe what would happen if I had to D/L one.I had no luck with the 1370 card I had,I figured it was just the card.
    Dec 2003
    77
    i have installed the ct4810 and disabled my onboard ac97
    windows recognizes the 4810 and installs all the drivers properly
    i even have the volume icon on my tray
    but here is the PROBLEM : i can't hear shit !!! i push play on winamp or any other sound player (even games) and it pops up an 220h error or something like that
    directx also gives me sound unrecognized error.
    please help me
    Apr 2003
    PA. USA
    3,310
  1. Bad playback
    By ramvi in forum General Tech Discussion
    Last Post: May 7th, 2003, 06:01 PM
  2. Surround Sound doesn't work
    By jmoore2001 in forum Multimedia and Audio
    Last Post: April 24th, 2003, 05:14 PM
  3. ensoniq 1370-0001 driver
    By thePh@r@oh in forum Technical Support
    Last Post: March 22nd, 2003, 07:04 AM
  4. DVD Drive won't read cd's and dvd's anmore.. help!!! :(
    By _raziel_ in forum Technical Support
    Last Post: April 21st, 2002, 01:47 PM
