Results 1 to 8 of 8
    Nov 2004
    56
    problem playing back up dvds
    i hope this is the right forum section.
    i have a matshita dvd-rom sr-8176
    long story short.....
    it wont play back up dvds.
    it plays my originals fine, but i try to play the back ups and it says
    "Windows cannot read this disc. The disc might be corrupted, or it could using a format that is not compatible with Windows."
    any ideas,
    help is appreciated.
    sirhc
    Ultimate Member [Neo770]'s Avatar
    Gold Coast,Australia
    2,477
    First thing that comes to mine is can it read the media your using , eg if your burning DVD+R try getting a DVD-R disk and see if it makes any differance.
    Member Bluesguitar's Avatar
    Jan 2005
    NE
    201
    But if the backups are ones he burned, why could it burn them and not read them? (I am assuming here that by backups, you mean dvds you yourself burned on your computer with that burner) Does it do that on all the backups or just some? Because if it only does that on some of them, I would say try higher quality media. (Spend more on the blank DVDs).
    But then what do you mean by "my originals." The more I think about it the more confused I get! What are the "originals" and what are the "backups?"
    Ultimate Member Xtreeme's Avatar
    Apr 2003
    PA. USA
    3,310
    It must be the way your making the disc.
    Nov 2004
    56
    when i say the originals, i mean the dvd's i bought at the store. backups are the ones i burned, not with the same drive, the burner is external, i'm using fujifilm dvd+r. didnt think of the dvd-r. i either copy the whole dics menus' and all... or i only copy the movie.
    let me ask this. the error message i'm gettin, does it sound like a problem with the dvd drive, or could it be like the software, or decoders. others have recommended that, but it has worked out for me.
    Ultimate Member yohon125's Avatar
    Jan 2003
    Cary, NC
    1,350
    will the discs read in another reader or player? what brand of media are you using?
    what? like a blue spider? get it off!
    http://live.xbox.com/member/BMF Yohon
    Feb 2005
    25
    i'm pretty sure he means movie dvds he rents and rips.
    it is wierd that you can't play it on the same drive you burned it on..
    what program are you using to:
    A. rip the movie
    B.burn the movie
    does the movie play in a regular standalone TV dvd player?
    i see you said it's a matshita dvd-rom sr-8176, could the shit be coming out of it?
    lol just kidding-
    good luck
    Super F@D Folder
    Jun 2004
    5,091
    how are you burning the movie? you can't just copy the files from one drive to the other....you need to use a program to do it like nero (or if nero won't do it) dvd shrink
  1. dvd playback troubles
    By kendy in forum Technical Support
    Last Post: January 16th, 2005, 03:23 AM
  2. Toshiba Satellite 2450 DVD Backup Problem
    By Vanoss in forum Mobile Computing
    Last Post: August 20th, 2004, 08:55 PM
  3. DVD reading problems
    By slall in forum Multimedia and Audio
    Last Post: August 27th, 2003, 06:31 PM
  4. What % of DVD Movies can't be ripped?
    By patyoda in forum Multimedia and Audio
    Last Post: August 16th, 2003, 02:42 PM
  5. Lycoris Linux ?
    By EvilRick in forum Applications and Operating Systems
    Last Post: March 4th, 2002, 11:29 AM
