Results 1 to 6 of 6
    Apr 2005
    19
    No sound device detected ?
    I have just been given a system with a Gigabyte GA-8ST800 and I have done a fresh instal and I have no sound? I get the message "No sound devise detected" when I run DX program. In the bios the AC97 is enabled, any ideas?
    NOVA
    33,809
    46
    did you load the latest drivers for the sound card?
    You can get them from the makers of the motherboard website
    Aug 2003
    Gateshead U.K.
    11,322
    the ac97 may be enabled, but you usually have another setting to enable the onboard sound, as well as that one. look for integrated peripherals or similar in the bios.
    Apr 2005
    19
    re the drivers, I thought the bios/chipset would contain the basics for that? Its AC97 on board sound.
    Ultimate Member Jarhed7276's Avatar
    Apr 2003
    Texas
    2,230
    In the second link from your last thread you will find the audio driver. I'll repost the link here. Download and install the driver.
    http://www.giga-byte.com/Motherboard..._GA-8ST800.htm
    The driver you need is the second one on the page: Audio Driver.
    Apr 2005
    19
    Downloaded the driver and it wont instal? Think I'll buy a soundcard, this one must be damaged to not recognise/ totally reject the driver !
  1. No sound device or video card
    By 3cho in forum Graphics Cards and Displays
    Last Post: August 13th, 2004, 10:53 AM
  2. Replies: 3
    Last Post: December 30th, 2003, 02:14 AM
  3. audigy not detected
    By aznxguy2o9 in forum Multimedia and Audio
    Last Post: March 24th, 2003, 02:56 PM
  4. Sound card not detected
    By lost-and-found in forum Technical Support
    Last Post: October 5th, 2002, 09:50 PM
  5. Sound card detected, installed, no sound.
    By Eli in forum Multimedia and Audio
    Last Post: March 27th, 2002, 09:14 PM
