NEC DVD burner wont burn CD's
Currently Active Users: 1641
Discussions: 200,988, Posts: 2,379,874, Members: 246,359
Old April 21st, 2005, 03:09 PM   Digg it!   #1 (permalink)
cracked's Avatar
Send a message via AIM to cracked
hi all. ive had this dvd burner for a few weeks. it burns dvd's fine, but every time i try to burn a data cd it goes crazy. i dont know what to make of this error report but here it is anyway:
duroo
1A23-2049-2057-5817-9841-5790
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.56, size=163910 bytes, created 4/2/2003 9:13:44 AM
Nero version: 6.0.0.0 (Nero Express)
Recorder: <_NEC DVD_RW ND-3520A> Version: 1.04 - HA 1 TA 1 - 6.0.0.0
Adapter driver: <> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <_NEC DVD_RW ND-3520A >Version: 1.04 - HA 1 TA 1 - 6.0.0.0
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD400JB-00ENA0 05.0 nvidesm Port 0 ID 0 DMA: ?
DiskPeripheral : WDC WD400BB-32CXA0 02.0 nvidesm Port 0 ID 1 DMA: ?
CdRomPeripheral : _NEC DVD_RW ND-3520A 1.04 nvidesm Port 0 ID 0 DMA: ?
DiskPeripheral : WDC WD1600JB-00EVA0 15.0 nvidesm Port 0 ID 1 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523764kB)
Free physical memory: 118MB (121052kB)
Memory in use : 76 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
21.4.2005
CD-ROM (MP3)
2:02:16 PM #1 Text 0 File Isodoc.cpp, Line 5451
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
2:02:16 PM #2 Phase 75 File dlgbrnst.cpp, Line 1818
JustLink activated
2:02:16 PM #3 Text 0 File Reader.cpp, Line 118
Reader running
2:02:16 PM #4 Text 0 File Writer.cpp, Line 127
Writer _NEC DVD_RW ND-3520A running
2:02:16 PM #5 ISO9660GEN -11 File geniso.cpp, Line 3814
First writeable address = 0 (0x00000000)
2:02:16 PM #6 Text 0 File Burncd.cpp, Line 3081
Turn on Track-at-once, using CD-R/RW media
2:02:17 PM #7 Text 0 File DlgWaitCD.cpp, Line 224
Last possible write address on media: 359847 (79:59.72)
Last address to be written: 163024 (36:15.49)
2:02:17 PM #8 Text 0 File DlgWaitCD.cpp, Line 229
Write in overburning mode: FALSE
2:02:17 PM #9 Text 0 File DlgWaitCD.cpp, Line 1688
Recorder: _NEC DVD_RW ND-3520A;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 49 (LO 79:59.73)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
2:02:17 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 757
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 163025 (163025) = #163025/36:13.50
relocatable, CD pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 163023 blocks [_NEC DVD_RW ND-3520A ]
2:02:17 PM #11 Text 0 File Burncd.cpp, Line 3318
Recorder and media-info
Burning to _NEC DVD_RW ND-3520A on a CD-R media
2:02:17 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 910
Prepare recorder _NEC DVD_RW ND-3520A for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 334182400
2:02:17 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 938
Removed 2 run-out blocks from end of track 1.
2:02:17 PM #14 Phase 24 File dlgbrnst.cpp, Line 1818
Caching of files started
2:02:17 PM #15 Phase 25 File dlgbrnst.cpp, Line 1818
Caching of files completed
2:02:17 PM #16 Phase 36 File dlgbrnst.cpp, Line 1818
Burn process started at 32x (4,800 KB/s)
2:02:17 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 2104
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
2:02:17 PM #18 Text 0 File Mmc.cpp, Line 18119
Set BUFE: JustLink -> ON
2:02:31 PM #19 SCSI -500 File Cdrdrv.cpp, Line 1361
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03FD0000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
2:02:31 PM #20 Text 0 File Writer.cpp, Line 455
14:02:31.312 _NEC DVD_RW ND-3520A : WriteBuffer reduced to 32768 Bytes
2:02:31 PM #21 Text 0 File Writer.cpp, Line 318
14:02:31.328 - _NEC DVD_RW ND-3520A : Queue again later (Intervall : 13msec)
2:02:35 PM #22 SCSI -1064 File Cdrdrv.cpp, Line 1361
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Code: 0x21
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x21 0x02
2:02:35 PM #23 CDR -1064 File Writer.cpp, Line 335
Invalid block address
2:02:35 PM #24 Text 0 File ThreadedTransfer.cpp, Line 227
all writers idle, stopping conversion
2:02:35 PM #25 Text 0 File ThreadedTransfer.cpp, Line 221
conversion idle, stopping reader
2:02:39 PM #26 CDR -201 File WriterStatus.cpp, Line 191
Invalid write state
2:02:39 PM #27 TRANSFER -18 File WriterStatus.cpp, Line 191
Could not perform EndTrack
2:02:39 PM #28 Text 0 File Mmc.cpp, Line 13141
<_NEC DVD_RW ND-3520A > start Close Session
2:03:05 PM #29 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 0:00,000 (0ms) -> OK
2:03:05 PM #30 Phase 38 File dlgbrnst.cpp, Line 1818
Burn process failed at 32x (4,800 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 12/20/2004 2:37:14 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
the burner is a NEC DVD_RW ND-3520A
the weird thing is that it says in device manager that it is a scsi device, but it isnt???
what should i do to fix this? any ideas?
oh yeah, im running winxp sp1 and using nero 6
Visit http://duroo.org
cracked is offline   Reply With Quote
NEC DVD Burner not recognized TheWildMan2000 General Tech Discussion 7 September 16th, 2004 12:48 AM
NEC 2510a DVD burner problem scgoer General Tech Discussion 5 August 4th, 2004 02:19 PM
neeh help!!my Samsung dvd-rom SD-616F wont recognize DVD but can read CD's MARCUS AURELIUS General Tech Discussion 5 August 3rd, 2004 10:36 PM
DVD +/- burner $80 AR - NEC 1300A?? I_W ResellerRatings Homepage Deals 2 December 14th, 2003 05:55 AM
nec 1300a dvd burner problem blowfly Technical Support 3 November 6th, 2003 04:10 AM
Is It Just Me? (3069)
Health Care Rationing (12)
Delete an OS (17)
Nvidia GTX 260 problem (10)
Internet Lost (5)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
cell phone won't work (0)
Can't open Word (12)
