Results 1 to 18 of 18
    Ultimate Member mjolnir1134's Avatar
    Jan 2005
    The Internet
    1,997
    Good enough 5,1 sound??
    Hi there hi there..... Oo
    I was thinking of buying cheap 5.1 sound. Wattage doesn't matter to me (even though I have heard that it doesn't matter as much in other websites) and I don't set the speakers so blazingly and deafeningly loud... Of course I'd want some bass to enjoy my Halo tunes!
    Is this ok?
    http://www.newegg.com/Product/Produc...82E16836131011
    Oh, and me mobo already supports 5.1 sound...so...umm.... would I get better sound anyways if I went from the "Realtek 97" onboard to whatever this card gives me?
    http://www.newegg.com/Product/Produc...82E16829120103
    EEE 1000H—1.6Ghz—1GB RAM—XP
    Jan 2003
    Milwaukee, WI
    7,657
    I doubt you would notice a difference using the card unless your an Audiophile and using MUCH better speakers...
    Onii-san Bizkitkid2001's Avatar
    Sep 2002
    San Antonio
    10,929
    Those set of speakers aren't gonna give you the bass responce you would like from the Halo soundtracks.
    Try to find a pair that can go at least down to 50hz and post back.
    When you look for the 50hz frequency, check in the Frequency Range part of the specs.
    Jan 2005
    The Internet
    1,997
    http://www.newegg.com/Product/Produc...82E16836131001
    Do those puppies look promising? I love the rumbly effect from the bass!
    I'm not really much of an audiophile, I would say I'm the above average casual user!
    Sep 2002
    San Antonio
    10,929
    yes, those are better.
    Jan 2005
    The Internet
    1,997
    yay-ness!
    Ultimate Member pinipig523's Avatar
    Aug 2003
    ChiTown, IL
    1,320
    The second one doesnt look good to me. My friend has one and it blows beyond belief. I would suggest going up to atleast a set that is offered by creative or logitech. The 530 by logitech would be a very decent system.
    Audio 1337:
    SB3 -> PS Audio Digital Link III DAC -> Cary SLP-05 Reference tube preamp -> Plinius SA-102 amp -> Martin Logan Summit
    Sep 2002
    San Antonio
    10,929
    I would suggest that too, but if he is looking for $25 speakers, I am sure he is not wanting to get $50-$80 speakers.
    Jan 2005
    The Internet
    1,997
    ehh... I just wanted to switch from my 2.1 speakers (some kind of 15Wor something Labtec Speakers, had it since 1999! O.O) Wondering if any of those speaker suggestions would at least be better than those 6 year old things.
    Anything thats better than what i have now for cheap is what i'm lookin for!
    Sep 2002
    San Antonio
    10,929
    The cheapest speakers that I would even consider buying would be these.
    http://www.newegg.com/Product/Produc...82E16836121126
    Jan 2005
    The Internet
    1,997
    Well, I'll keep my mind on those logitechs, but wondering, whats the difference of OEM and Retail? What am I missing in the OEM package? Hopefully I'm not missing cables or anything important like that... I dont mind the extra bit of pricing in the retail.
    Sep 2002
    San Antonio
    10,929
    OEm means that everything will come in a brown box, and the warranty may be less than the retail. I'm not to sure about OEM vs Retail on speakers with warranty.
    But all the wires should be present in the OEM version.
    Jan 2005
    The Internet
    1,997
    Kewl beans kewl beans... I'm gonna start ransacking my entire house for coins (and theres a lot lying around my house mind you) and go to the grocery store to put it in that coinstar thing to get washingtons and lincolns on paper!! I only have 28 bux in my wallet, and I get 20 bux for helping to clean teh house.
    Jan 2003
    Milwaukee, WI
    7,657
    http://www.newegg.com/Product/Produc...82E16836121119
    Im sure even these would be quite an upgrade from what you have if your not looking to spend too much money...
    the trouble with 5.1 is the back satelites... few people have a good setup that allows easy use of the back speakers...
    most logitechs have pretty decent bass and these are MUCH better sounding than the DCT ones you linked ...
  15. #15
    Aug 2003
    ChiTown, IL
    1,320
    My advice is not to get the really cheap 5.1 because you may be in for a disappointment. Specs mean nothing and I remember that those things dont have any kind of musical coherence whatsoever. And I am not saying this in comparison to my setup... I am saying this relative to nothing. The sub, if you look closely, is made of 5mm plastic. The sats are about .5 pounds and the distortion of the entire setup is abysmal.
    If you want to waste your money on that, then buy it. If you want something that is decent, save up a little and get the 530.
    Audio 1337:
  16. #16
    Jan 2005
    The Internet
    1,997
    530 it is then
    pinipig knows his audio.....
  17. #17
    Sep 2002
    San Antonio
    10,929
    yeah, but I posted a link before he did
    grrr....
  18. #18
    Aug 2003
    ChiTown, IL
    1,320
    Yes... I suceeded in bringing him to the dark side.
    Excellent.
    Good job, too, BK... you deserve your just credit.
    Audio 1337:
  1. DO these sound like good speakers?
    By Bizkitkid2001 in forum IMO Community
    Last Post: February 15th, 2005, 08:14 PM
  2. is this good sound?
    By ajna_star in forum Multimedia and Audio
    Last Post: August 21st, 2004, 03:55 AM
  3. Good Sound system
    By teengeek88 in forum Multimedia and Audio
    Last Post: January 27th, 2004, 03:35 PM
  4. What's a good sound card and a good speaker?
    By Dj-Icer in forum Multimedia and Audio
    Last Post: November 6th, 2003, 11:19 PM
  5. Does this sound like a good deal?
    By shampoo in forum General Tech Discussion
    Last Post: May 22nd, 2002, 09:01 AM
