Antenna Help!!!
Currently Active Users: 1498
Discussions: 200,926, Posts: 2,379,129, Members: 246,292
Old August 5th, 2005, 04:34 AM   Digg it!   #1 (permalink)
Antenna Help!!!
I need help! What is the difference between VHF and UHF? What is a Gold-Plated "F" connector antenna input? I am looking at the Zenith ZHDTV1 HDTV/UHF Digital Indoor Antenna and want to know what those fetures are! Will it allow me to watch channles 2-13? Someone help me understand this thanks!
GHawsJR is offline   Reply With Quote
Old August 5th, 2005, 03:04 PM     #2 (permalink)
radio1_mike's Avatar
Send a message via ICQ to radio1_mike
Arrow
Hi.
VHF = Very High Frequency (Ch 2 -13)
UHF = Ultra High Frequency (Ch 14 - 8x)
Frequencies are measured in Hz (cycles per second, peak to peak). Anything above 440MHz is considered UHF, anything below (that is to the HF limit) is VHF.
An F-connector is the 'cable TV'-type connector at the of the coaxial cable.
The Zenith antenna you are looking at, does get all the channels you are looking for. But it is a Yagi-design antenna- so it is directional. So you will have to adjust the antenna to pick up certain stations...
HTH-
Mike
New Dad since 07/06/2005
radio1_mike is offline   Reply With Quote
Old August 5th, 2005, 03:21 PM     #3 (permalink)
Human voltmeter
DanU's Avatar
I checked the specs on that antenna. It WILL NOT receive channels 2-13. It is a UHF only antenna, so you can only receive channels 14 to 83. You will need a separate VHF antenna to receive channels 2-13, or just go with a dual VHF/UHF antenna.
That is no Yagi antenna. It looks like a log-periodic antenna. Log-periodics are also directional so Mike's advice to point the antenna towards the strongest signal still applies.
Old August 5th, 2005, 04:13 PM     #4 (permalink)
My bad. I have not designed an antenna for awhile.
Old August 5th, 2005, 05:01 PM     #5 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
I have a question-my damily wants a new antenna, since satellite is $30+ a month and cable isn't here. I presume I'd need a "combo" antenna to get both, right [VHF and UHF]?
And, it would have to be a very powerful antenna, since Green Bay is a 100+ miles away and our current one reaches that far. Also, we have a tower height of ~30 feet. Any recommendations?
http://www.ubuntu.com
Old August 5th, 2005, 05:54 PM     #6 (permalink)
Human voltmeter
DanU's Avatar
Reather,
If all the transmitters are located in the same direction, then you can use a very high gain combo antenna with lots of elements like this one: http://www.winegard.com/offair/pdf/pr-7052.pdf .
What type of cable are you using for the antenna connection? Is it RG-59 coax or twin-lead? How long is the cable from your TV(s) to the antenna? If it's fairly long and you're using those types of cables then I would try replacing it with burial grade RG-6 coax. If you're splitting the signal several times for many TV's then I would also recommend using an amplified splitter.
Old August 5th, 2005, 11:36 PM     #7 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
Yeah, we primarily watch stations to the south, but occainsonally some ~ due North. I have no idea what cable I have, but I do know I have a very small wire coming from the cable. And, it is a long cable, about 50+ feet.
Edit-I also have an antenna turner, for the current directional antenna.
Old August 8th, 2005, 10:57 PM     #8 (permalink)
Human voltmeter
DanU's Avatar
If you have an antenna rotator then your're set! Just get yourself one of those high gain antennas.
Usually the type of cable is printed on the cable itself. RG-59 should be fine for a 50' run, although you'll lose less signal if you switch it out to RG-6, especially on the higher UHF channels.
Old August 8th, 2005, 11:17 PM     #9 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
Now I'll need is the $$.
TV Antenna Question cheeser General Tech Discussion 2 June 13th, 2005 07:02 PM
Am antenna Armadel General Tech Discussion 5 April 21st, 2004 11:41 PM
Have you ever made an AM antenna? surreal IMO Community 40 March 1st, 2004 05:10 PM
antenna pointing deane1935 Networking and Internet 15 February 15th, 2004 12:52 AM
AM/FM antenna advice osprey4 IMO Community 11 February 3rd, 2003 08:30 PM
Is It Just Me? (2865)
Obama the Muslim (14)
Regular Build (0)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
