PLEASE HELP (PCI multimedia audio device)
Currently Active Users: 1503
Discussions: 200,933, Posts: 2,379,168, Members: 246,297
Old August 10th, 2005, 02:51 AM   Digg it!   #1 (permalink)
Exclamation
my mom thought it would be a good idea to screw arround with my computer and format it on me. i re-installed windows 98 se and i cant five where the pci multimedia device is. i know i have a soundblaster card but i am unshure of what version it is. i have a floppydisk for it (Sound plaster CD-ROM installation Disk p/n 1200001091) but it doesnt want to install whe is on it. i would like help getting the driver or how to find out what version of soundblaster i have so i can get a
driver.
thank you for your time,
Samual siedler
P.S. please save me from pulling out all my hair.
samualsiedler is offline   Reply With Quote
Old August 10th, 2005, 03:00 AM     #2 (permalink)
Instigator
Atomic Rooster's Avatar
Send a message via AIM to Atomic Rooster Send a message via Yahoo to Atomic Rooster
Download and install EVEREST Home Edition. It will tell you what you need to know about your system. Including the soundcard type. Then you can go to Creative's download site and grab the newest drivers.
Atomic Rooster is offline   Reply With Quote
Old August 10th, 2005, 03:03 AM     #3 (permalink)
thank you so much. will tell you how it goes once i am done.
Old August 10th, 2005, 03:43 AM     #4 (permalink)
Angry
turns out i have a ESS Technology ES1938/ES1946 Solo-1(E) AudioDrive any ideas as to where i can get the driver i need? thanks.
Old August 10th, 2005, 06:03 AM     #5 (permalink)
rabidaardvark's Avatar
http://www.nodevice.com/ESS.html
First hit in google searching 'ES1938/ES1946 Solo-1(E) drivers'.
size=1 rocks
rabidaardvark is offline   Reply With Quote
Need drive "PCI Multimedia Audio Device" Guimaraes Motherboards 8 January 31st, 2008 11:41 PM
Portable multimedia handheld device Wrincle Mobile Computing 0 February 6th, 2005 02:43 AM
no audio device??? WAKKA2223 Multimedia and Audio 13 August 22nd, 2004 12:26 PM
no audio device miriam Technical Support 3 May 30th, 2004 01:27 AM
newbie needs help on going from onboard audio to pci sound card audio Xenos Multimedia and Audio 21 January 23rd, 2002 08:39 PM
Is It Just Me? (2875)
Obama the Muslim (14)
Ideal cheap graph card for PC-Gamin.. (17)
CPU fan stops spinning randomly (0)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
