MP3 Home Audio & Car Audio
Currently Active Users: 1795
Discussions: 200,923, Posts: 2,379,105, Members: 246,290
Old August 27th, 2005, 05:15 PM   Digg it!   #1 (permalink)
Question
I am having trouble finding a cd player which you can also store Mp3's or Wav on a HD. I know there are car receivers which you can now directly hook up an ipod (ipod capability). This would also be great if there was a receiver or CD Player which I could hook an IPOD up to. I am not sure, but can you hook an IPOD up to mostly any ol' home receivers or not? I am guessing by directly hooking the IPOD up to a home or car receiver, there would be a minimal loss in sound quality. I would really appreciate the help! Thanks.
ry4n is offline   Reply With Quote
Old August 27th, 2005, 05:18 PM     #2 (permalink)
ph34r t3h g04t
Whir's Avatar
You can, and there won't be any appreciable loss in sound quality.
Old August 27th, 2005, 05:19 PM     #3 (permalink)
_Switch_'s Avatar
yep...alls you need is a 1/8'' stereo to rca y adapter (red/white) which plugs into the back of ur reciever....or an optical cable if it's high endish
_Switch_ is offline   Reply With Quote
Old August 27th, 2005, 05:37 PM     #4 (permalink)
Sweet, I can sell my CD player then. I didn't know if there was a stereo output directly from the IPOD. I was just looking at the dock, but that only works for the picture 30gb+ ipods, and I will most likely get a 6gb or 20gb. Also I don't need to store picture or use slideshows. Thanks.
Old August 27th, 2005, 06:01 PM     #5 (permalink)
Anyone know how the ipod mini 6gb holds up? I heard the battery life on the 20gb+ diminishes somewhat.
Burning MP3 Cds for car audio system techlesswonder Multimedia and Audio 15 August 16th, 2005 12:06 PM
Car Audio italiamodena575 Multimedia and Audio 14 March 5th, 2005 01:34 PM
Car Audio Amp Question JayMan Multimedia and Audio 9 December 26th, 2002 03:01 AM
Internet Audio for home audio systems daveleau Multimedia and Audio 0 May 12th, 2002 07:25 PM
MP3 CD Car Audio Players cracked Multimedia and Audio 14 March 29th, 2002 03:37 AM
Is It Just Me? (2856)
Obama the Muslim (14)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
