Good, inexpensive RCA to USB
Currently Active Users: 2296
Discussions: 200,919, Posts: 2,379,038, Members: 246,287
Old September 20th, 2005, 02:59 PM   Digg it!   #1 (permalink)
Hey all, I am looking for an inexpensive RCA in to USB adapter for recording audio.
Something like THIS but a little more affordable.
Anyone have any recommendations? I looked at guitar center online but didn't see much.
TIA
jp22382 is offline   Reply With Quote
Old September 20th, 2005, 03:09 PM     #2 (permalink)
HeadBand's Avatar
if your soundcard has a line in you could pick up an adapter at radio shack or $2 and not have to bother getting an entire external usb sound processor
Hey who turned sigs on?
Old September 20th, 2005, 03:11 PM     #3 (permalink)
thats the thing, all i have is a mic port, no line-in
Old September 20th, 2005, 03:50 PM     #4 (permalink)
Human voltmeter
DanU's Avatar
I just looked at the manual for your SFF mobo. You don't have a line-in on your motherboard but you do have a CD-in. Using a spare CD audio connector and with a little bit of wire splicing you can plug one of your front ports into the CD-in and use the CD-in as the input of your recording application.
OR
You could buy an external USB sound adapter. The Philips Aurilium was being sold on clearance for $20 a while back. They're sold out now on the Philps web page, but you should be able to find some on Ebay.
Old September 20th, 2005, 04:49 PM     #5 (permalink)
hey, now that is an idea
I just checked ebay, I can get one of those sound cards on ebay for dirt cheap.
I suppose what I could do is use a rca to headphone jack cable, and run it into the line-in. My guess is the sound quality would be just as good as running the rca's right into a sound card?
Old September 20th, 2005, 08:58 PM     #6 (permalink)
HeadBand's Avatar
that basically is a soundcard that uses usb instead of pci...i got one of the phillips he mintioned for my laptop but i have not had a chance to try it out yet
another option would be to pick up an internal card with a line in and use that...they can be found for under $10
Old September 20th, 2005, 09:20 PM     #7 (permalink)
the usb option is nice since i could haul it around and use it with my laptop too.
Old September 21st, 2005, 12:57 PM     #8 (permalink)
Human voltmeter
DanU's Avatar
My friend uses the Aurilium with his laptop... it's a terrific way to upgrade the sound capabilities on laptops and other limited expansion, small form factor type PCs. The quality is much higher than laptop or mobo on-board sound as well.
Old September 29th, 2005, 10:14 PM     #9 (permalink)
radio1_mike's Avatar
Send a message via ICQ to radio1_mike
Lightbulb
You can also get this from Turtle Beach for $24:
http://www.newegg.com/Product/Produc...82E16829118107
Creative also has a similar unit for about $48...
New Dad since 07/06/2005
radio1_mike is offline   Reply With Quote
Old November 20th, 2005, 05:37 PM     #10 (permalink)
That is a nice looking product, but unfortunately it doesn't seem to have line-in.
RCA Cable modem recognizes USB not Ethernet glover12 Networking and Internet 4 July 9th, 2004 09:29 AM
Good inexpensive camera! Darthgary General Tech Discussion 25 January 30th, 2004 04:58 PM
Is this a good deal for an inexpensive CPU? gpzaz ResellerRatings Homepage Deals 2 September 11th, 2003 09:17 PM
USB Mouse, USB Keyboard, 56K USB Modem w/4-Port USB Hub for $25.50 lovelydeals ResellerRatings Homepage Deals 0 July 3rd, 2002 09:23 AM
good inexpensive program to help me make good pics for links and flash Chooco Graphic Design and Digital Photography 11 March 5th, 2002 08:45 PM
Is It Just Me? (2844)
Obama the Muslim (9)
Foreign voltage (8)
Print spooler problem (10)
Virus Doctor Popup? (1)
Foreign voltage (8)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
