Cd/Dvd Drive Problem
Currently Active Users: 1834
Discussions: 200,923, Posts: 2,379,099, Members: 246,290
Old November 12th, 2005, 01:51 PM   Digg it!   #1 (permalink)
Ok i have a Dynex 16x DVDRW Dual Layer Internal Drive, and I had to replace my motherboard (to put a new vid card in) the vid card turned out bad so i put my old mobo back in tmeporarily. But when i did this, under my computer there USED to be a D and E drive from my dvd player, one was the cd and other was the dvd, but now only the dvd part of it shows up, and it will only read dvds, therefore it wont read my mobo's driver cd nor the dvd player driver cd.. I dunno what to do so could any 1 help me?
NotTheWorthy1 is offline   Reply With Quote
Old November 12th, 2005, 02:24 PM     #2 (permalink)
Fixed it, nvm ^_^
Argh! Blank CD-Rs not recognzied on neither DVD/CDRW combo nor DVD R drive Zombie Technical Support 2 August 26th, 2005 01:52 AM
Problem with my DVD Drive :( gunstar Technical Support 1 May 25th, 2005 12:19 PM
CD-RW/DVD Combo Drive Problem NightRise420 Multimedia and Audio 5 January 16th, 2005 07:17 PM
DVD Drive Mechanical Problem? mar122999 Technical Support 2 November 10th, 2003 06:14 PM
DVD Drive Problem with windows XP? mar122999 Technical Support 3 November 10th, 2003 01:07 PM
Is It Just Me? (2856)
Obama the Muslim (13)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
