Thread: how to chain mpegs?
March 14th, 2002, 12:26 AM #1
how to chain mpegs?
hey,
any kind of apps out there i can use to string mpegs together as one? links are much appreciated. i dont think its possible in nero or cheezey-cd creator but i have both. thanx
SD
March 14th, 2002, 12:29 AM #2
hrmm i see the tux... i hope ure thinking for a win box, so here's a site for ya:
http://www.eo-video.com/
March 14th, 2002, 12:31 AM #3
http://www.tmpgenc.com/e_main.html
This is a good all-around editing program. It is fairly well documented as well. You can of course link MPEGs with it.
Good luck
Dave
March 14th, 2002, 12:34 AM #4
I tried this one and it does the job right ... its a shareware but if you can handle the register popup in every start .. then you can keep using it (something like winzip registration) :
http://download.cnet.com/downloads/0...st-7-4.8836198
Or was you talking about Linux ? .. in that case i have no idea
Regards
<edit> and this is a free one .. which i didn`t try, but reviews show its good ..
http://extra.newsguy.com/~theprof/Readme.html
OMG ..i`m ultra slow
March 14th, 2002, 01:47 AM #5
thanks for the links but i made a mistake. its avi format for the most part but there are some mpegs so its not all a loss.
i have to find something do merge avi's i see now
thanks
March 14th, 2002, 01:49 AM #6
umm if you look mine does avi's too or so it says
March 14th, 2002, 01:54 AM #7
damn you Pshawn5!. i just tried it and was gonna say forget my post...........you were too quick!
thanks. great little program.
March 14th, 2002, 02:30 AM #8
hehehe..glad i could help....and glad it wasn't linux..or we would still be stumped
March 14th, 2002, 09:15 PM #9
If you have few MPEG files you want to join, this would be the simplest way (in command prompt) :
copy /b file01.mpg + file02.mpg + file03.mpg + ... + filexx.mpg onebigfile.mpg
March 14th, 2002, 09:23 PM #10
No kiddin'! Check this out though.... Is WMIprvse a real villain? - Windows Management Infrastructure Blog - Site Home - MSDN Blogs Enjoy!
BSOD on Vista Home Premium
