"Stereo Mix" audio recording option
Currently Active Users: 2656
Discussions: 200,520, Posts: 2,374,497, Members: 245,842
Old July 2nd, 2008, 11:23 PM     #21 (permalink)
It did not work
I have followed all the suggestions at this site and others, but even when I install the new drivers (LG, new Dell drivers, whatever), and I get the stereo mix to show up in my recording properties, it doesn't actually WORK like stereo mix. It still only records either the microphone or the sound I am trying to record simultaneously.
I have been attempting to use a USB interface (Tascam), but this isn't doing anything except giving me better vocal quality. I am a recording artist and need my computer to have "what you hear" record capabilities in order to get my demos done on deadline. Otherwise, I have to patch everything together, overdub, and crap like that.
If anyone has any other suggestions about how to get this to work, including ways to get the USB audio interface to make simultaneous recordings, please let me know. I'll be eternally grateful!
V
P.S. I'm not trying to start any sort of argument, but I can sort of understand why the "what you hear" recording can be controversial for recording artists. Not all of us members of the RIAA are "Big Stars" and we can barely scrape a living through our CDs and small concert tours and shows. I had several of my songs stolen in the midst of a month long recording session, and by the time it was time to master my CD, my small but upcoming label said no-go because too much of my music had been pirated online - it didn't make sense to spend money mastering it. On the plus side, I realized people actually like my music but it was frustrating because I couldn't afford to master and press all the CDs myself. Hence, the music, which I spent countless hours writing and preparing, was never released officially. While copyrighted, what recourse do I have now?
StopHypocrites! is offline   Reply With Quote
Old July 12th, 2008, 12:58 PM     #22 (permalink)
Send a message via AIM to phondo2 Send a message via Yahoo to phondo2
Question
No Stereo Mix on New Dell XPS420 with Vista and Creative SoundBlaster X-FI XTREME CRD
Hello Everyone. I am so upset. Last month I bought a new Dell XPS420 with Vista. It came loaded with a Soundblaster X-FI XTREME GAMER Card. I have no option for Stereo Mix. I used my 9 year old computer to record on singsnap.com. Now with this new awesome pc, no stereo mix so it no longer records the music playing , only my voice. I heard that this card does not support that function, however, there is a #20.00 USB Converter that can be purchased here:
Amazon.com: Behringer U-CONTROL UCA202 USB-Audio Interface: Musical Instruments
Can anyone reccomend a sound card for my system that will support this function? Or should I buy this audio converter? Thanks for the help!
Pam in GA
phondo2 is offline   Reply With Quote
Old May 18th, 2009, 12:49 AM     #23 (permalink)
Smile
I have a sony vaio with sygmantel sound
Originally Posted by numbernine View Post
Download this driver and install in windows xp sp2 mode if you are using vista.
http://ftp.us.dell.com/audio/R171789.exe
Works for sigmatel stac c-major 92xx
GOOD LUCK!
Worked on my dell inspiron 1520, i hope it will work for other machines too using the sigmatel vista
IF you have a different model sigmatel try installing other XP drivers using compatibility mode.
I need instructions for a vaio sony that have sygmantel in vista. Going crazy!!!!
The_Muse is offline   Reply With Quote
Old June 25th, 2009, 12:54 AM     #24 (permalink)
A solution for Dell XPS 400 and Sigmatel Audio missing Stereo Mix
Originally Posted by FireSka View Post
I have this EXACT same problem. I just got a new computer and there is no option for it. I paid a lot of money for this computer too and I work with audio so I need this option. I don't really want to go buy and install an entirely new sound card. Is there any way to get this option back? I bought a Dell XPS400; SigmaTel audio.
Here is what worked for me today! YAY!
I have a Dell XPS 400. This computer has an Intel D945G-series motherboard.
I went to the Intel motherboard web site
Go to Downloads
Search for "sigmatel" or "D945GCL"
Located the Sigmatel driver for WinXP
Downloaded this file: 5.10.5208_W3_XP32_XP64_2K_wSTACGUI_UPMIX_AC'97FP_V 2.EXE
"Audio driver with support for legacy AC'97 front panel header plus the Sigmatel* software interface."
Installed this file, no reboot needed. Checked in Device Manager; Dell driver is dated 2005, the above Intel driver is dated 9/7/2006 (for the "SigmaTel High Definition Audio Codec")
Here's a direct Link to the driver file: Intel® Desktop Board D945GCLÂ*Audio: Sigmatel 9220/9221/9223 (I made a shortcut)
Stereo mix now MAGICALLY appears!
Tried it out with MixMP3, a great free command line tool for ripping audio streams from "Stereo Mix"...and it worked PERFECTLY!
I am a happy man now
throw2k is offline   Reply With Quote
Old July 11th, 2009, 09:43 PM     #25 (permalink)
sigmatel stereo mix problem solution
Hi
For Stereo mix problem
Here is the solution:
First uninstall the audio driver.
go through this link and download the software
extract it then
1. Right click on set up.exe.
2.click properties
3.click compatability tab
4. Mark " Run this program in compatability mode for"
5. Select Windows XP(service pack 2)
6.Click apply and OK
7. Install the setup.exe now.
restart the system. Then you can see the option Stereo mix in recording devices in volume mixer.
Enable Stereo mix. Set that stereo mix as default.
That's it.
Note: Dont update the driver.
pradeepz_reddy is offline   Reply With Quote
Old July 11th, 2009, 09:44 PM     #26 (permalink)
Hi
extract it then
2.click properties
That's it.
Old September 7th, 2009, 02:52 PM     #27 (permalink)
Thumbs up
Download this driver and install in windows xp sp2 mode if you are using vista. http://ftp.us.dell.com/audio/R171789.exe Works for sigmatel stac c-major 92xx GOOD LUCK! Worked on my dell inspiron 1520, i hope it will work for other machines too using the sigmatel vista IF you have a different model sigmatel try installing other XP drivers using compatibility mode.
It's September 2009 and your suggestion to use the driver listed above still works. Incidentally I've a Dell with XP and just removed the device and then rebooted and installed the 'old' driver.
I've been looking for a way to make 'stereo mix' appear for some hours now so well done and thank you.
z0wkey is offline   Reply With Quote
Old September 9th, 2009, 04:30 PM     #28 (permalink)
Unhappy
NEED HELPPPPPP
I HAVE A GATEWAY MODEL M-7331H RED..... i HAVE NO CLUE WHAT MY SOUNDCARD IS, BUT MY LAST LAPTOP ACER I COULD HAVE STEREO MIX ON IT, I REALLLY NEED TO FIND A WAY TO PUT IT ON THIS LAPTOP CAN ANYONE PLEASE HELP?? *IM A GIRL* DONT KNOW WHAT IM DOING....
TUPACSGIRL16 is offline   Reply With Quote
Old September 23rd, 2009, 09:28 PM     #29 (permalink)
Hi, I've tried all this and I'm still having problems ...
I have a Dell XPS M1530, running Vista. I uninstalled the SigmaTel codec and installed the older XP driver. It's working fine.
HOWEVER, Stereo Mix still will not show up in the sound devices list. (I have the disabled/disconnected boxes ticked.)
I'm really frustrated, I've tried everything I've been able to find online. I hope someone can help. Thanks.
lanakau is offline   Reply With Quote
Old September 24th, 2009, 06:57 AM     #30 (permalink)
Worth remembering this is a workaround/hack and even if the steps are followed correctly it won't work for all configurations.
You could contact your PC manufacturer for advice. This is a potentially pointless exercise but maybe just maybe you'll get lucky and hit someone helpful. Who knows maybe customer feedback might be useful in the long term (highly debatable).
Or you could take the advice above to buy an external sound card. That would fix your problem.
Senate reaches deal, no "nuclear option" needed John Prophet IMO Community 12 May 26th, 2005 12:36 PM
long delay after pressing "print" before option box pops up zskillz Technical Support 2 April 7th, 2005 07:16 PM
My home stereo...back in "the day"... OuTpaTienT IMO Community 9 March 11th, 2004 01:54 AM
Car stereo "kick = dim" joker_927 General Tech Discussion 22 December 4th, 2003 09:32 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Is It Just Me? (1660)
HELP!!! What do you think of this s.. (25)
windows 7 retail and rtm (5)
Review My Build (6)
My 1st pc build (40)
Aero in Vista (7)
[F@H SPAM 11/1/09]New month . . . n.. (34)
slaving laptop drive (7)
[F@H SPAM 11/08/09] Where has all the.. (1)
nvidia geforce 9500GT 1gig DDR2 (3)
[F@H SPAM 11/1/09]New month . . . new.. (34)
Endless BSOD to Recovery Manager loop.. (0)
HELP!!! What do you think of this sys.. (25)
New Processor, Monitor will not turn .. (3)
Determining ip route and serial addre.. (8)
can u beat freecell # 1941? (11)
Dell 8300 Graphics Problems (1)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
