"Stereo Mix" audio recording option
Currently Active Users: 2223
Discussions: 200,920, Posts: 2,379,023, Members: 246,286
Old September 24th, 2009, 04:07 PM     #31 (permalink)
Originally Posted by z0wkey View Post
Or you could take the advice above to buy an external sound card. That would fix your problem.
I'm not really knowledgeable in this stuff, I just ran into problems with some video/audio needs on my computer and traced it to the fact that I don't have the Stereo Mix option on my laptop. Point being: any info as to what I should be looking for, as an external soundcard, to ensure that it will give me this feature?
I guess I could try one and return it if it doesn't produce the results I want.
lanakau is offline   Reply With Quote
Old September 24th, 2009, 04:23 PM     #32 (permalink)
Go to your local store, if they're any good, they'll be more than happy to meet your needs if you tell them what you're trying to do. Online I can see cards from 10 $/€ upwards - there's some really nice kit for around 50 - anyway it's up to you.
I would imagine most if not all external sound cards will have the option to record directly from them but you should check with the vendor before you pay.
Good luck and maybe post back what you ended up with and if it's any good.
z0wkey is offline   Reply With Quote
Senate reaches deal, no "nuclear option" needed John Prophet IMO Community 12 May 26th, 2005 12:36 PM
long delay after pressing "print" before option box pops up zskillz Technical Support 2 April 7th, 2005 07:16 PM
My home stereo...back in "the day"... OuTpaTienT IMO Community 9 March 11th, 2004 01:54 AM
Car stereo "kick = dim" joker_927 General Tech Discussion 22 December 4th, 2003 09:32 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Is It Just Me? (2838)
Obama the Muslim (9)
Foreign voltage (8)
Print spooler problem (10)
Foreign voltage (8)
Help getting around port 80 for camer.. (0)
I need help getting around blocked po.. (0)
Virus Doctor Popup? (0)
Browsers wont load websites (0)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
