Results 1 to 6 of 6
    Feb 2006
    montana
    6
    i've got an audio problem
    hi i anyone can help my computer crashed i downloaded my win.xp back into it and now i have no audio a friend mentioned my motherboard may have gotten erased how can i fix this
    Sep 2002
    Iowa
    3,404
    A little more info will help...
    what motherboard, what sound card if not using the onboard sounds etc.
    Also, this is the 3rd topic you started regarding this, please only make 1 topic instead of posting a lot for the same issue...it will make it easier for us to help you and easier for you to find the help in the responses we give to the topic(s)
    Aug 2003
    Madison, WI
    15,225
    Feb 2006
    montana
    6
    i not sure what a mother board really is im just have no sound i sorry but im not the britest when it comes to my computer.
    Sep 2002
    Iowa
    3,404
    Quote Originally Posted by mostlymoosey
    http://www.majorgeeks.com/download4181.html
    go to that site and select one of the mirrors given to download Everest. Install the program then run it and then go to the computer section then the motherboard section there and it will giove all of the info you need regarding the manufacturer and other usefull info.
    Sep 2002
    Iowa
    3,404
    hp pavillion 751n is the computer mostlymoosey is using.
    here is a link to to the poage that has the soundcard drivers for your computer on it. Look for the Hp Pavilon 751n driver.
    http://www.soundcard-drivers.com/companies/456.htm
  1. Audio problem - Different from other audio problem
    By battousai_himura in forum Technical Support
    Last Post: October 30th, 2005, 07:18 AM
  2. Another Audio Problem!
    By Zombie in forum Technical Support
    Last Post: January 31st, 2005, 01:13 AM
  3. Audio CD Problem
    By PastranA in forum Technical Support
    Last Post: August 29th, 2003, 04:26 AM
  4. Audio problem
    By robby3_16 in forum Motherboards
    Last Post: February 4th, 2003, 09:27 PM
  5. Problem with CD audio.
    By Dputiger in forum Technical Support
    Last Post: December 6th, 2001, 05:08 AM
