Onboard sound AND a sound card
Currently Active Users: 2313
Discussions: 200,944, Posts: 2,379,284, Members: 246,305
Old April 6th, 2006, 03:20 PM   Digg it!   #1 (permalink)
Big_Daddy's Avatar
I have onboard sound. If I add a sound card, will both sources be active? IOW, can I hook my headphones to the sound card output and my speakers to the onboard output?
Big_Daddy is offline   Reply With Quote
Old April 6th, 2006, 03:25 PM     #2 (permalink)
mjolnir1134's Avatar
Nope. Only one source will be used at a time. Otherwise it would cause conflicts and the like.
If you want headphones to be plugged in your computer, they can get sound from:
1)Your speaker satellites (if they have any headphone plugs on them) (and if the speakers are connected to the sound card)
2)Directly from your sound card output plugs.
EEE 1000H—1.6Ghz—1GB RAM—XP
mjolnir1134 is offline   Reply With Quote
Old April 6th, 2006, 03:39 PM     #3 (permalink)
Friedchicken100's Avatar
Send a message via AIM to Friedchicken100 Send a message via Yahoo to Friedchicken100 Send a message via Skype™ to Friedchicken100
Some sound cards and onboards allow you to configure the jacks through proprietary software. I wouldn't try running a card AND onboard. It might cause IRQ conflicts or compete for system resources.
My other car is a T-34.
Friedchicken100 is offline   Reply With Quote
Old April 6th, 2006, 03:39 PM     #4 (permalink)
分かりますか。
carl33p's Avatar
Send a message via AIM to carl33p
If you are going to add a sound card, make sure to disable onboard sound first.
carl33p is offline   Reply With Quote
Old April 6th, 2006, 06:50 PM     #5 (permalink)
Human voltmeter
DanU's Avatar
You can successfully have both your on-board sound and a sound card installed. I've done it before and it works fine. You can switch between the two in the "Sound and Audio Devices" control panel. However, there can be only one "default" sound adapter. Windows will use this sound card for all it's system sounds, and most programs will default to using the default sound adapter.
Most programs will allow you to output to audio devices other than the "default device" selected in the control panel. You could have one audio adapter used as the primary windows audio adapter while another program (like an mp3 player) using the other audio adapter. Some specialized software will even input and output to/from multiple sound cards at the same time, but most software can't do this.
Different sound levels. onboard and sound card PastranA Technical Support 4 March 28th, 2006 11:09 AM
No sound device with Onboard sound..... Aspire Multimedia and Audio 1 September 20th, 2005 07:05 PM
onboard and pci sound card problems.. sweeper2 Multimedia and Audio 10 April 30th, 2005 05:35 PM
onboard sound card sktdude Motherboards 3 December 29th, 2004 02:19 AM
sound card or onboard sound??? sweeper2 Multimedia and Audio 15 March 12th, 2004 10:47 PM
Is It Just Me? (2916)
Wireless Televisions. (9)
Regular Build (6)
cheap AF1,AF1XXV,gucci,jeans,belt,bra.. (0)
Asus P4G8X Mobo (4)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
