Results 1 to 11 of 11
    Member Del80y's Avatar
    Nov 2005
    Scotland
    124
    No Display when sound card is installed
    Hey all
    Well i bot myself a new sound card for my computer. A Sound Blaster Live Model : SBOO6O. (its second hand from ebay). ok so when i install it onto my motherboard and turn my computer on the computer starts but there is no pictuer on my monitor. I can not work out how this is iv googled but with no luck . So please help is my sound card broke or is there somthing i have to do before i can get it to work.
    System spec.
    Athlon 2700+
    Winfast K7S741MG
    Geforce 5500 AGPx8
    1GB RAM
    Windows xp SP2 media center edition
    Human voltmeter DanU's Avatar
    SF Bay Area
    4,214
    Try resetting your CMOS. Have you tried installing it in different PCI slots?
    Mar 2005
    England
    1,083
    does it (pc) work again once you remove the soundcard
    Nov 2005
    Scotland
    124
    Yes i have tryed all the PDI Slots but nothing :9
    Yes once i pull the sound card from the computer and start it again everthing goes fine. I have also tryed the sound card on my sisters computer and my mates computer and even on there' this happens. I am now thinking the card is broke and i am going to have to contact the guy i bot it from and try and get my money back
    Ultimate Member radio1_mike's Avatar
    Weymouth, MA
    1,777
    Smile
    Sometimes audio and video cards can share IRQs- this might be the problem.
    Go into your BIOS settings and make sure you have the settings Assign IRQ to AGP and Assign IRQ to PCI enabled. Also, change the ECSD setting to enable and then reboot.
    If this does not work, go back into BIOS and turn off PNP OS installed, this will have the BIOS determine IRQs versus Windows.
    Hope this helps-
    write back, so we can troubleshoot more.
    New Dad since 07/06/2005
    Nov 2005
    Scotland
    124
    I tryed assignin IRQ to AGP and IRQ to PCI but i still get on signal on my mointor. I was looking at the sound card when i noticed that there are pin's on it, there is on long line of pin that underneth it says "AUD_EXT", AND FOUR OTHER SMALLER ONES "TAD, CD_IN, AUX_IN, AND CD_SPDIF". Do you think i have to pulg somthing into these. It never came with any wires or any thing
    Member demon_wolf's Avatar
    Jan 2004
    Kentucky
    364
    "I tryed assignin IRQ to AGP and IRQ to PCI but i still get on signal on my mointor. I was looking at the sound card when i noticed that there are pin's on it, there is on long line of pin that underneth it says "AUD_EXT", AND FOUR OTHER SMALLER ONES "TAD, CD_IN, AUX_IN, AND CD_SPDIF". Do you think i have to pulg somthing into these. It never came with any wires or any thing"
    The CD_IN is the wire from your Main CD Drive/DVD Drive etc. This carries the Sound signal from the Device to your Sound Card.
    The AUX_IN is for a Second CD Drive/DVD Drive etc. So, you can plug a second Device in.
    Your Main Device will have a Wire that runs from it to your Motherboard. Just unclip it from the Motherboard and into CD_IN.
    If you have no wires running to the Sound Card you will have NO SOUND.
    Also, go into your BIOS and Disable Onboard Sound if it is enabled. If On Board Sound is Enabled, and you install the Sound Card sometimes what you are experiencing can happen. I do know this happened to me a while back, and that was the problem.
    If that does not work, the Sound Card could be Dead, but..... even if it is, it should not affect the rest of the System as it is doing.
    Hope this helps some.
    Main Rig:
    AMD A64 3500+ E4 (Manchester - One Core Disabled)
    Back Up Rig:
    Intel P4 2.8 ES (Engineering Sample)
    Wifes Rig:
    AMD Athlon XP2900+
    Weymouth, MA
    1,777
    You don't actually need to hook up any of those wires to your sound card to get sound out of them. The data will travel through the IDE channel from the drives also.
    You can also set system resources through Windows. Go into control panel and then system. You can then check system resouces and see if the the IRQs for video and audio are shared. You can then assign different IRQs if you have some available.
    Otherwise, maybe you can just go back to onboard sound?
    West Haven, Utah
    32,653
    It sounds like you've tried everything that I would have tried. If you've tested it in all your PCI slots and on several computers with the same results, chances are that the card itself is fried.
    Member yeadon563's Avatar
    Jun 2002
    326
    Could be a conflict with the soundcards drivers. Have you tried Windows update to see if they have drivers for your soundcard?
    Yeadon563
    West Haven, Utah
    32,653
    If it won't even POST with video while the card is installed, I doubt that drivers could have any effect.
  1. GFX card stops working with drivers installed
    By Postal Dude in forum Graphics Cards and Displays
    Last Post: November 27th, 2005, 04:00 PM
  2. ATI card removed, NVidia installed: no sound
    By crazyray in forum General Tech Discussion
    Last Post: November 6th, 2004, 04:29 PM
  3. Sound card detected, installed, no sound.
    By Eli in forum Multimedia and Audio
    Last Post: March 27th, 2002, 09:14 PM
