Thread: how convert .cda to .mp3
August 1st, 2006, 12:23 AM #1Junior Member
- Jul 2006
- 24
I borrowed some music CD's from the library last week, and downloaded them to my pc. Each song has a .cda extension.
How do I convert them to mp3 files? I no longer have the original music CD's.
Thanks for taking time to read this.
Vegas_girl
August 1st, 2006, 12:32 AM #2
google ".cda convert .mp3"
Download and try out some of the programs... Free trial is all you need if your just using it this one time.
Or you could proly download a music recording program, and record the songs to mp3 format.....
August 1st, 2006, 12:33 AM #3
The only way I know how to do that requires you to burn those songs onto a CD, then use Windows Media Player (I assume you are using windows) to rip those as WMA files, and then using one of the thousands of free programs out there to convert WMA to MP3.
August 1st, 2006, 03:57 AM #4Junior Member
- Jul 2006
- 24
Thank you gentlemen for your feedback. I have downloaded 2 freeware programs I found through a google search.
Unfortunately they will only work if I have a CD with .cda files on the cd.
But the .cda files are currently sitting on my hard drive.
I can't believe there isn't a conversion program to take all the files with .cda I have on my hard drive and let me convert them to mp3.
thanks
vegas_girl
August 1st, 2006, 04:46 AM #5Retired mostly.
- Oct 2001
- Location
- Finland
- 5,150
Your .cda files are all probably 1kb size and they really contain no relevant information. What you need to do is use some audio-ripping program on the original cd's to rip the wav files that are present.
August 1st, 2006, 04:52 AM #6Unfortunatly she dosn't have them...
Originally Posted by vegas_girl
August 1st, 2006, 10:13 AM #7
Try just going to www.download.com and searching for a free demo program that can covert the audio files. You might need to try a couple before you find one that works well, but its probably the easiest solution.
-awe sha
August 1st, 2006, 10:17 AM #8Member
- Aug 2005
- 85
A small, free app called "switch" is easy to use and does the cda to wave/mp3 converting.
August 1st, 2006, 10:33 AM #9
Isn't this piracy, therefore against forum rules... unless the cd's aren't copywrited...
August 1st, 2006, 10:38 AM #10
AS said in the post above, what you have on your hard drive now amount s to a shortcut, not the audio file. You must start from the original CD. No other way.
Convert Mpeg to MP3
By Vyx in forum Multimedia and AudioReplies: 0Last Post: October 18th, 2005, 08:54 PM -
Convert cassette to mp3
By sickmaggot in forum Multimedia and AudioReplies: 24Last Post: July 1st, 2005, 03:47 PM -
.CDA to .MP3 converter needed
By mad1 in forum Multimedia and AudioReplies: 6Last Post: January 12th, 2005, 09:17 PM -
How to convert mp3 to WMA?
By hbcao2004 in forum Multimedia and AudioReplies: 21Last Post: December 31st, 2004, 02:34 AM -
convert .wma to .mp3?
By dar1again in forum Multimedia and AudioReplies: 1Last Post: March 15th, 2002, 06:54 PM
. It is brand-new and completely warranteed by manufacturer for one year. Price it without mouse and keyboard. Assume decent-to-high quality parts. Thanks. Brand-new Retail with one-year Warrantee...
How much would you Say this...
