RCA vs USB
Currently Active Users: 2169
Discussions: 200,919, Posts: 2,379,039, Members: 246,287
Old September 8th, 2007, 01:59 PM   Digg it!   #1 (permalink)
RCA vs USB
I want to connect my PC to my receiver to play music only. My main reason for this is to have my monitor on top of the bar while leaving my sound system where it is, 50ft away. Need assistance as to which way to go. I do want good sound but do not want to spend a fortune on cables. I see my options are:
1) Store the PC close to the monitor and run RCA cables to the receiver. Do I need to spend $$$ on good RCA cables to prevent signal loss?
2) Connect PC to the receiver with normal length RCA cables and run USB repeaters to the mouse and keyboard. I will also have to run monitor cable the same length.
Side question: do I need a higher quality sound card then the supplied audio output on the PC (green colored input)?
Thanks Dave
Which of the two has less signal loss?
bandit233 is offline   Reply With Quote
Rca cable amplifier? how long can rca cables be run? spinsykel General Tech Discussion 8 September 5th, 2008 10:57 PM
Good, inexpensive RCA to USB jp22382 Multimedia and Audio 11 November 21st, 2005 08:49 AM
RCA Cable modem recognizes USB not Ethernet glover12 Networking and Internet 4 July 9th, 2004 09:29 AM
RCA Lyra help? cure4glass General Tech Discussion 1 June 27th, 2004 06:12 PM
USB Mouse, USB Keyboard, 56K USB Modem w/4-Port USB Hub for $25.50 lovelydeals ResellerRatings Homepage Deals 0 July 3rd, 2002 09:23 AM
Is It Just Me? (2844)
Obama the Muslim (9)
Foreign voltage (8)
Print spooler problem (10)
Virus Doctor Popup? (1)
Foreign voltage (8)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
