Results 1 to 3 of 3
    Oct 2004
    57
    no sound when converting 3gp to avi
    hey i made a movie on my video on my mobile yesterday and wanted to convert it to avi and edit it, but when i converted it using zwei-stein [full version 1.1] no sound came out any ideas how to fix this? thanks very much in advance
    trik.
    Ultimate Member CujoRbd's Avatar
    Everywhere
    1,050
    did this work before with zwei-stein? if so, you might be using damaged 3gp files, so try it with another one. if it doesn't work with any files, but it used to, there's probably a process or program running on your computer that caused a problem during the conversion. use the following instructions to determine if this is the case:
    http://support.microsoft.com/kb/310353/en-us
    haven't used that one... try converting with the following tool:
    http://www.videohelp.com/tools/Mobile_3GP_converter
    Oct 2007
    To convert 3gp file, you'd better install a correct decoder, perhaps Haali Media Splitter or QuickTime Alternative.
    Btw, I've tried many programs to convert 3gp to other formats, but much perfer winavi.
  1. converting avi into wmv
    By flyguyspy in forum Multimedia and Audio
    Last Post: March 1st, 2007, 01:17 PM
  2. Converting RMVB to AVI
    By Del80y in forum Multimedia and Audio
    Last Post: April 10th, 2006, 05:44 PM
  3. Converting avi files
    By galehickey in forum Multimedia and Audio
    Last Post: September 10th, 2004, 04:04 AM
  4. Converting .avi to mpeg
    By dlh75 in forum Multimedia and Audio
    Last Post: March 26th, 2004, 06:34 PM
  5. need help converting avi to mpg
    By farscape in forum General Tech Discussion
    Last Post: June 1st, 2003, 12:34 PM
