Results 1 to 2 of 2
    Member lhsonic's Avatar
    Nov 2005
    Coquitlam, BC
    334
    SoundBlaster Digital Out Minijack Question
    Hi,
    I just got an Audigy card and it has a digital out minijack.
    How can I use this to output to my receiver?
    My old sound card came with a minijack adapter + optical cable... I tried using the minijack adapter on this new sound card but there's no optical light so I don't think it works like that...
    Human voltmeter DanU's Avatar
    SF Bay Area
    4,214
    The digital out should work just fine. You may need to enable it in your Sound Blaster control panel. Digital out is probably defaulted to OFF, which would explain the lack of the red glow from the port.
    What do you mean by minijack adapter? Do you mean an optical to electrical (toslink to coax) converter?
  1. question on soundblaster audigy 2 platinum zs
    By allenfi in forum Multimedia and Audio
    Last Post: March 1st, 2004, 04:43 PM
  2. SoundBlaster Live Question
    By NDC in forum Technical Support
    Last Post: June 23rd, 2002, 11:26 PM
  3. soundblaster question: pls help!
    By capybara in forum General Tech Discussion
    Last Post: April 10th, 2002, 08:44 AM
  4. Digital Camera question
    By Rhino in forum Technical Support
    Last Post: February 5th, 2002, 05:49 PM
  5. Quick question on Soundblaster cards
    By Bones1 in forum General Tech Discussion
    Last Post: January 10th, 2002, 10:34 PM
