Results 1 to 20 of 20
    Ultimate Member BluesMan1's Avatar
    Jun 2003
    Not on this planet..
    1,102
    Extracting audio from a show
    I have a video from a show and i'm using Blaze Media and Acala to extract the audio files from that show. I succeeded extracting and converting the files with Blaze Media.
    It seems that i can do it but it gives me a bunch of files (VTS_1_0) with the MP3 format but it seems to be too big to be added to a regular CD-R that i can play in my car.
    What would be the best way to extract audio files from a DVD and put them on a regular CD-R media ?
    I'm on this since 5 am this morning and it is now 1:30 pm and i'm just about to declare it "arrghhhhh"
    Any additional information that you may have to make it easier would save me from climbing the walls
    Banned Keymaker's Avatar
    Jan 2005
    Loveland, CO
    5,490
    2
    Not sure what the free trial will allow, but I use
    Xilisoft DVD Ripper
    Last edited by Keymaker; February 2nd, 2008 at 02:46 PM. Reason: Deleted a comment.
    Jun 2003
    1,102
    Thanks Keymaker, i'll see what i can do with it
    Jun 2003
    1,102
    Xilisoft is working, i have now mp3's but even then the files are too big to fit on a regular CD-R....
    Is there anything that i need to do after that to have them fit ?
    Thanks again
    Jun 2003
    1,102
    Oups, my mistake,
    I'm using Nero Express and i didn't see that it was DVD rather than CD-R that was in the menu selection at the top... my bad
    Seems that i'm going to be able to burn the files.
    Thanks again Keymaker
    Jan 2005
    Loveland, CO
    5,490
    2
    Your welcome.
    Jun 2003
    1,102
    Now another problem, seems that it is happening only to me
    I can not burn the files, it looks like that Nero wants to create an image of the files but that is the only option that i have, no other options are available. If i try to make a music CD, it's too big for a CD-R and if i keep the mp3 format, i can only create an image
    Did i do something wrong ? It's becoming funnier all the time
    Aug 2003
    Gateshead U.K.
    11,307
    Create an image, then burn that to CD.
    Jan 2005
    Loveland, CO
    5,490
    2
    How big is the mp3/s ?
    Don't use express.
    Attached Thumbnails Attached Thumbnails Extracting audio from a show-nero-music.jpg
    Jun 2003
    1,102
    The mp3 files are 200 Meg all together, if i try to change that to .Wav for a Music CD it gets a lot bigger than that.
    Aug 2003
    Gateshead U.K.
    11,307
    Are you running into a problem with the length of time of the recording?
    What capacities of blank CD-R and CD-RW discs are available?
    Manufacturers commonly express disc capacity in terms of how much Red Book digital audio (in minutes) and computer data (in megabytes) a disc can contain. Historically, 63 minute/550 MB (12 cm) and 18 minute/158 MB (8 cm) discs were once available but are now rendered obsolete by advances in recording technology. Currently, 74 minute/650 MB, 80 minute/700 MB (12 cm) and 21 minute/185 MB (8 cm) discs are the market standards.
    From http://www.osta.org/technology/cdqa7.htm
    Jun 2003
    1,102
    In .Wav format it's too big to fit on a regular CD-R, with the mp3 format it's around 200 Meg so it should be working but it's an image. I'm going to try to burn the image and see if i can make it work.
    Thanks for the replies
    Jun 2003
    1,102
    Ok now, i can burn the image, no problem but that is not what i need to do, the image is not a sound file (.nrg) and it doesn't play the songs.
    I don't know if there is anymore options available with Xilisoft DVD Ripper but i'll try again and see if there is some more options to extract the audio from the show.
    Aug 2003
    Gateshead U.K.
    11,307
    So you are trying to burn it as a .wav data file instead of as an audio CD?
  15. #15
    Jun 2003
    1,102
    I tried mp3 format, .wav format, audio CD and it's not working.....
  16. #16
    Jan 2005
    Loveland, CO
    5,490
    2
    MP3 can be burned on to a CD-R directly playable on any player that supports mp3 media. You can copy the files to the drive and just burn using explorer. However, you want a regular CD? I
    It should burn the tracks. You can give Deepburner a try.
  17. #17
    Jun 2003
    1,102
    I succeeded at burning the mp3 files and it is playing on my computer. I also try Audio CD but then it doesn't fit on a regular CD-R.
  18. #18
    Jan 2005
    Loveland, CO
    5,490
    2
    A CD holds 700 MB..
    I think its due to the conversion that takes place to make it a regular CD. However, there should be more than enough room for 200 MBs of converted MP3s. Have you tried Deepburner to make a regular CD?
    Last edited by Keymaker; February 5th, 2008 at 06:16 AM. Reason: Thought it was 750
  19. #19
    Jun 2003
    1,102
    mp3's are about 200 megs, for the .wav format it's a lot bigger.
    I removed the unnecesary audio files like interviews and others and it's still too big in wav format.
    I didn't try Deepburner, will do it and see what it does.
    Thanks again
  20. #20
    Jun 2003
    1,102
    Tried Deepburner, for the Audio CD all together the files are 1.5 Gig so there is no way that i'm going to be able to put them on a regular CD.
    I guess that i'm going to keep them in mp3 format
  1. Extracting Audio From DVD
    By J1mmy in forum General Tech Discussion
    Last Post: March 26th, 2007, 12:02 AM
  2. all my videos show up as audio on itunes and ipod!
    By GH0STce11 in forum General Tech Discussion
    Last Post: July 27th, 2006, 11:32 PM
  3. extracting mp4 audio
    By galehickey in forum General Tech Discussion
    Last Post: May 15th, 2006, 02:55 PM
  4. Extracting Audio from .wmv
    By Namie in forum Applications and Operating Systems
    Last Post: December 1st, 2003, 12:43 PM
  5. Extracting an MPEG from BIN/CUE
    By Epo_Man in forum Multimedia and Audio
    Last Post: January 21st, 2003, 03:15 PM
