Join TechIMO for Free!
Thread Tools
Currently Active Users: 2432
Discussions: 186,731, Posts: 2,228,406, Members: 230,394
Old May 21st, 2008, 09:27 AM   Digg it!   #1 (permalink)
Exclamation
Audio Driver Problem
I have a XFX nForce 680i LT SLI Mobo, when i put the driver in to install theres two options, one for the audio, and one for everything else, the "everything else" one installs ok, but when i install the audio driver it says it intalls but it never does.
in case u need to know:
ge-force 8800gt superclocked edition
core 2 quad q6600
4g ram (corsair)
windows xp sp3
does ne1 know how to solve this problem?
xeneize368 is offline   Reply With Quote
FREE instant scan
Old May 21st, 2008, 09:38 AM     #2 (permalink)
Kawaru wa yo!
Whir's Avatar
Are you using the CD that came with the motherboard?
If so, have you tried to download the newest platform drivers from nvidia.com?
Are you sure the onboard sound is not somehow deactivated in the BIOS?
Old May 21st, 2008, 10:11 AM     #3 (permalink)
i am using the cd that came with the mobo
ill try downloading the newest platform and let u know what happens, and im pretty sure i dont have to nething in the bios
Old May 21st, 2008, 10:34 AM     #4 (permalink)
the new platform didnt fix the problem either, i have to go to work now but ill try again when i come back
Old May 21st, 2008, 07:27 PM     #5 (permalink)
hmm, i still keep getting the same problem, i dont know why the audio driver wont install :/
Old May 21st, 2008, 08:16 PM     #6 (permalink)
Banned
DeathWish187's Avatar
Send a message via AIM to DeathWish187
I don't know the specifics of what came with the disc, but I know for the boards I've gotten some of the software on the installation disc screws shit up and is not recommended to install.
DeathWish187 is offline   Reply With Quote
Old May 21st, 2008, 09:58 PM     #7 (permalink)
i checked under program files, and it seems to be installed, but for some reason it just wont run idk wtf is going on
Old May 21st, 2008, 10:18 PM     #8 (permalink)
ShyguyXPC's Avatar
When you say won't run, as in no sound?
If so, check to make sure its plugged into proper jack.
Make sure the Windows volume control doesn't have sound muted.
make sure under Sounds and Audio Devices Properties (right click volume icon in systray, select Adjust Audio Properties), under the Audio tab, make sure the onboard sound is selected for the various options, as well as under the Voice tab too.
and as someone else suggested double check to make sure Audio isn't disabled in the bios, not sure about the 680i boards, but for some boards there actually is two options in bios for onboard audio, one to disable the chip, the other to diable the codecs for it...
I'm running a 650i board, but can't remember what the settings were on mine. it was either this one, or the Socket 939 NForce 4 SLI board I had prior to this that had something like that in it. (thinking it was the old board, as that one had an onboard Sound Blaster Live! 24-bit chip)
Old May 21st, 2008, 11:19 PM     #9 (permalink)
there is no windows volume control, its exactly as if it wasnt installed, except that all the files are in their corresponding folders, no sure what the systray is cause there are absolutely no volume icons what so ever on the screen =/
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
audio driver help jagnorm Technical Support 6 October 28th, 2006 06:37 PM
Audio Driver Problem bjun Technical Support 1 February 18th, 2006 09:47 PM
K8VSEDX mobo audio-driver problem :( jap0 Motherboards 9 February 11th, 2005 08:32 PM
on board AC97 audio driver problem Gilthanaz General Tech Discussion 2 August 21st, 2004 07:08 AM
Audio driver Cruez Technical Support 4 May 17th, 2002 01:22 PM
Is It Just Me? (778)
Service Pack 3 (5)
Newegg WARS!!! (57)
Car Talk! (8698)
E5200 15.2GHZ?? (12)
Best graphics card for around $600 (8)
Folderchat: The Holiday thread (159)
TRUE 1080p LCD picture (25)
New info on the Phenom II X4 (46)
Box alive but monitor dead (2)
Compatible Mobo/CPU mystery (1)
Bought an AGP "HIS Radeon .. (22)
Just built new pc, restarts ran.. (2)
Fallout 3 problem (4)
Service Pack 3 (5)
replacing tvs msp345 printer he.. (1)
LCD monitor sizes and wide scre.. (4)
