Sound works when using itunes, media player, and games, but anything involving the internet gets muted. All video streamed from the net has no sound. I am sure the solution is probably just an easy settings change somewhere that I can't find...
Hi majere. You don't mention which browser you are using but if you are using Internet Explorer 6 or 7 maybe I can help.
Open your browser and at the top click on Tools, then Internet Options, then Advanced. Scroll down to Multimedia. See if there is a check mark in the box next to Play sounds in webpages. If not click on the box then click on apply at the bottom.
__________________ “Where do you put the bayonet?” (upon seeing a flamethrower for the first time)
-CHESTY PULLER, USMC
try downloading then reinstalling your sound driver
"Battle not with monsters, lest ye become a monster, and if you gaze into the abyss, the abyss gazes also into you" - Friedrich Wilhelm Nietzsche
