Thread: Speaker problems
August 20th, 2008, 07:34 PM #1Junior Member
- Aug 2008
- 6
Speaker problems
I noticed that my speaker plug was a little off center ( the one going into my computer) so I unplugged it and put it back in; then my speakers stopped working. Help.
August 20th, 2008, 07:58 PM #2
Did you try to restart your pc?
August 20th, 2008, 08:28 PM #3Junior Member
- Aug 2008
- 6
Yes
August 20th, 2008, 08:51 PM #4
Do you have onboard sound or sound card?
August 20th, 2008, 08:58 PM #5Junior Member
- Aug 2008
- 6
sound card i think
August 20th, 2008, 09:06 PM #6
I know this sounds silly but check and make sure its plugged into the right port. Hey i have done that myself. If you good there go into device manager and go into sound and take a look at media control devices to see if all is good there.
August 20th, 2008, 09:11 PM #7Junior Member
- Aug 2008
- 6
I tried that. When I plugged it in to the slot I have it in right now the speakers make a static-like noise, also when I adjust their volume.
August 20th, 2008, 09:14 PM #8
Are you using xp or vista? Also really need to know if your using onboard audio or sound card. If your using sound card more than likely your ports for the sound card will be more towards the bottom of the pc on the back.
August 20th, 2008, 09:14 PM #9Junior Member
- Aug 2008
- 6
xp
August 20th, 2008, 09:21 PM #10
Go to control panel in start menu. Click on sounds, speech and audio devices. Click on sounds, and devices click on the audio tab it will tell you there what kind of audio your using.
August 20th, 2008, 09:43 PM #11Junior Member
- Aug 2008
- 6
Thanks for your help.
August 20th, 2008, 09:50 PM #12
I take it you have it working now. If so good job! By the way welcome to techimo.
Speaker Problems.
By GalleryLOVE in forum Multimedia and AudioReplies: 3Last Post: November 23rd, 2006, 12:53 AM -
Strange Speaker Problems
By Creatures in forum General Tech DiscussionReplies: 6Last Post: November 3rd, 2005, 06:27 PM -
speaker problems
By swell22 in forum Multimedia and AudioReplies: 5Last Post: January 11th, 2005, 06:47 PM -
Speaker Problems
By dr_roberts49 in forum General Tech DiscussionReplies: 2Last Post: June 14th, 2003, 09:37 PM -
Speaker problems!
By Creatures in forum Multimedia and AudioReplies: 7Last Post: February 10th, 2003, 12:49 PM
I hope there is a time delay. I'd hate my deer rifle to go off in my trunk after the deer snuck back in to the brush...
The perfect gift for an aspiring...
