Join TechIMO for Free!
Thread Tools
Currently Active Users: 2363
Discussions: 186,731, Posts: 2,228,403, Members: 230,394
Old August 26th, 2008, 07:31 PM   Digg it!   #1 (permalink)
Samsung TV changes channel
I need help. Bought a Samsung 19" TV for the kitchen model LN19A450C1D. Within 30 minutes after going through Setup, the TV had changed channels by itself from HD 5.1 to 2.1. I called the retailer, HH Gregg, and then called Samsung. Neither had heard of such a problem. I returned the TV to HH Gregg and exchanged it for another TV of the same make/model.
Now the second TV is doing the same thing. I have had it now for about 5 hours, and it has changed from HD channel 5.1 to 2.1 six times.
The HD service is Comcast. I am not using the STB. The cable TV service connects directly to the television set.
The remote is not being press accidentally. In fact, the batteries were removed form the remote, and the TV still changed channels by itself.
Any chance there is a signal from Comcast that may be causing this? Any other ideas before I exchange this one for a different brand?
Thanks.
gopcs is offline   Reply With Quote
FREE instant scan
Old August 27th, 2008, 11:30 PM     #2 (permalink)
update
I called Comcast. They said that there is nothing in the cable signal to cause the television to change channels.
I attached rabbit ear antenna to the TV, set it to Channel 5-1 HD over-the-air, and it stayed on that channel all afternonn.
Totally baffling. Guess I will try an LG television.
Old August 28th, 2008, 01:19 AM     #3 (permalink)
Kawaru wa yo!
Whir's Avatar
What connection are you using from the cable box to the TV, or are you just plugging the coax from the wall straight into the TV?
Many TVs and receivers will automatically change between 5.1 and stereo when the input from the source changes. Typically this only happens via optical or HDMI. I am not sure if analog coax supports 5.1, not something I ever got into, but if it does, that could also be it.
If this is the case, the TV is working as intended.
Old August 28th, 2008, 11:40 PM     #4 (permalink)
Whir, thanks for the reply.
The coax goes directly to the television. When I called Comcast to register the problem, I confirmed with the CSR that they do indeed send local television station HD content on regular cable - - no converter box needed.
5.1 is local TV Channel 5 on HD over the air. On the Samsung TV, it is entered as 1-5. There is no audio problem, neither stereo nor otherwise.
Old September 12th, 2008, 10:16 AM     #5 (permalink)
Samsung TV changing channels
I think Samsung has a firmware problem with their TVs. When you connect directly to cable without a box, the list of digital channel numbers will constantly change. This happened to me with Comcast in Houston. Each time the list of channels change, they are added back to the good channel list. The newer TVs have a firmware update that seems to mostly fix the problem. Older TVs do not have an update. I think the best solution with an old Samsung TV is to only program the analog channels and get the digital channels off the air. During programming, you can unplug the cable around channel 64, and all the digital channels will be skipped. Even with the new firmware, you can unplug the cable around channel 90 and get all the good digital cable stations.
fredmon66 is offline   Reply With Quote
Old September 12th, 2008, 11:25 PM     #6 (permalink)
I think the mystery is solved. Seems Comcast does not send local channels in HD on regular cable service. The TV salesman said they did, as did the first CSR I spoke with at Comcast.
After having the same problem of channel 5.1 changing to 2.1 on two different TV sets, I called Comcast back. I spoke with a CSR and a Supervisor. Both told me that to receive any HD programming, a decoder box is required.
Seems the HD programming I was receiving without the decoder box was ingress to the cable network from the broadcast television transmitters. After installing a decoder box, the Samsung HD TV is stable.
Old September 29th, 2008, 10:05 AM     #7 (permalink)
I get Comcast local HD channels in Houston just fine, especially with my new Samsung TV. My old Samsung gets them also, but whenever I program them, the channels keep changing.
Of course the people at Comcast are going to tell you to get a cable box. They charge extra for that.
Old September 30th, 2008, 02:09 AM     #8 (permalink)
samsung random hd channel changing
my samsung lcd tv has randomly changed hd channels at least 5 time in 10 months, cable co. or samsung was able to tell me nothing
patrick7 is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
400mhz dual channel setup running at 320 mhz dual channel. s4087046 General Tech Discussion 7 November 30th, 2008 11:34 PM
Single Channel Dual Channel dr_roberts49 General Tech Discussion 1 September 19th, 2006 10:54 AM
which is better 512 (dual channel) / 768 single channel? Sweeper Processors, Memory, and Overclocking 19 January 4th, 2006 10:06 PM
Samsung 172X va Samsung 710T Dribbles Graphics Cards and Displays 4 October 23rd, 2004 01:54 PM
Is It Just Me? (778)
Service Pack 3 (5)
Newegg WARS!!! (56)
Car Talk! (8697)
E5200 15.2GHZ?? (12)
Best graphics card for around $600 (8)
Folderchat: The Holiday thread (159)
TRUE 1080p LCD picture (25)
New info on the Phenom II X4 (46)
Box alive but monitor dead (2)
Compatible Mobo/CPU mystery (1)
Bought an AGP "HIS Radeon .. (22)
Just built new pc, restarts ran.. (2)
Fallout 3 problem (4)
Service Pack 3 (5)
replacing tvs msp345 printer he.. (1)
LCD monitor sizes and wide scre.. (4)
