Sound card problems with Imedia 1307
Currently Active Users: 1510
Discussions: 220,964, Posts: 2,603,388, Members: 272,797
Old November 20th, 2008, 08:19 PM     #1 (permalink)
Hi,
My Packard Bell 1307 has a built in motherboard sound card, I upgraded this with a new dedicated sound card.
When I bought a new computer I transfered this sound card to the new computer, since then I have been unable to restore to the built in sound card.
Windows xp o/s
So trying to play an mp3 on media player for example.... I get the following error message.....
Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not be functioning properly.
I am not really very tech savvy so any help would be appreciated.
Thank you for your time
ANTIQCOOL is offline   Reply With Quote
Old December 25th, 2008, 06:00 AM     #2 (permalink)
bigBonehead's Avatar
It sounds like the bios is still looking for the add-in S/C.
If you right-click on 'My Computer' on the desktop, and scroll down to 'Properties' and left click on it, that will open a panel that has 7 tabs on it. Left click on 'Hardware' and then 'Device Manager'.... on that panel, scroll down to 'Sound, and Video Game Controllers' and left click on the +
That will open a list in which you should see the add-in S/C, and your onboard S/C. Left click on the add-in S/C, then go up to the top of that panel and left click on 'Action' and then 'Properties'. On the 'General' tab, go to the bottom and click the down arrow on 'Device Usage' ....Select 'Do not use this device'
Click 'OK'... Go back to the 'Device Manager' screen. Then select the onboard S/C, and click 'Action' 'Device Usage' and select 'Use This Device'.
Shut the computer off, wait ten seconds, and re-start. If the onboard S/C still doesn't work, post back, and I'll take you through a bios change...
>>>>> Edit <<<<<
You may want to print this before you start.... IMHO
bigBonehead is offline   Reply With Quote
Ask a Tech Question (free)!
Look who the cat dragged in... (15)
Is It Just Me? (3752)
This is evidence (19)
Diablo 3 is out! (13)
Need some help determining possible.. (9)
help with pesky laptop screen wire! (8)
F@H **Official** SPAM Thread 2012-0.. (478)
Intel(R) G45"G43 Express Chips.. (6)
How could wrong Amperage affect a l.. (29)
XP has gone cyclic missing SXS file o.. (6)
Tech support interview questions (1)
Edit file exe 16bit (3)
Building a gaming computer (0)
Windows 9 Internet Explorer rememberi.. (1)
Computer Memory (RAM) and Hard Drive .. (28)
F@H **Official** SPAM Thread 2012-02-.. (478)
Search Babylon (1)
Sound Muffled/Distorted, need help. (9)
1.163v safe for GTS 450? (1)
New GTS 450 freezing PC (29)
Display Problem (1)
Need some help determining possible u.. (9)
Viewing problem: HELP! (2)
Choosing a new graphics card (4)
my graphics card is not working (0)
my graphics card doesn't work (0)
H Martens (1)
Cloning a hard drive to DVD (12)
Want to restore outlook express addre.. (0)
Oh boy... lol (comp wont boot) (1)
remove network.connection (2)
Replace non working graphic card (0)
Reinstalled XP over existing XP but u.. (2)
Packard Bell iMedia pc problems... badgerspannerB Technical Support 3 July 4th, 2008 11:49 AM
Sound Card Problems? knightofnee Multimedia and Audio 3 August 4th, 2005 03:09 AM
Sound card problems! Linuxfreak Linux and Unix 2 April 11th, 2005 06:40 AM
Sound card problems Thenimrod Technical Support 8 August 10th, 2003 07:18 PM
Sound Card Problems Maximonium Multimedia and Audio 2 February 4th, 2003 01:01 PM
TechIMO Copyright 2012 All Enthusiast, Inc.
