Audio within a college network
Currently Active Users: 2307
Discussions: 207,853, Posts: 2,459,457, Members: 253,353
Old January 30th, 2009, 05:48 PM   Digg it!   #1 (permalink)
Hello,
I'm not sure if this is the right place for this question, but I'll give it a shot.
I'm a college student and work in our A/V department. We are trying to determine an easy (and cheap) way to basically remote monitor the output of our mixing board. The output from the board can be either an xlr or a 1/4" plug, and we could convert it to other formats (mini, rca etc.). It is not an option run some sort of line from the board to our office, as it is too far (though within the same building). We have access to the school's network via a nearby ethernet port. So is there an easy way to simply stream this audio to a specific location on the network (but not necessarily on the internet)?
Thanks, and if anything was unclear, feel free to ask.
drumtechjp is offline   Reply With Quote
Old February 1st, 2009, 12:30 AM     #2 (permalink)
bigBonehead's Avatar
Hey JP... not entirely sure if this is what you want:
Start Your Own Podcast Now. It is Free.
Wisdom comes with age, but sometimes age comes alone...
bigBonehead is offline   Reply With Quote
Old February 1st, 2009, 01:29 AM     #3 (permalink)
Well, not exactly, I the idea is we want to be able to monitor in real time (aside from whatever immediate streaming delay there may be) in our office, what is going through the sound system in our production facility. Thanks though. from what i could tell that didnt have the option to run a live podcast. I may have just missed it though. If so, please let me know. Thanks for the reply
Old February 1st, 2009, 11:56 PM     #4 (permalink)
How far apart are your office and production facilities?
Old February 2nd, 2009, 12:13 AM     #5 (permalink)
SoMuchAnime-SoLittleTime
EXreaction's Avatar
You do have access to a computer that it could be plugged into, right?
Old February 2nd, 2009, 12:40 AM     #6 (permalink)
yes EX, we can have a computer right near the sound board, and we also have one in the office.
and Bonehead, the office and the facility are approximately 200 yds apart (i think)
, tho they are still in the same building.
Old February 2nd, 2009, 12:51 AM     #7 (permalink)
EXreaction's Avatar
Alright, a bit of searching brought up this tutorial:
Streaming Audio over the LAN/Intranet
You should be able to hook the output from your board to the PC's mic input using an adapter. Keep the output volume for that line as low as possible so you don't damage the sound card in it.
Old February 2nd, 2009, 01:02 AM     #8 (permalink)
Great find EX.... I would only add that the line in on the S/C might be a better choice. If you are going to use the mic input, be sure the +20db box is un-checked in Audio properties if you are using XP, or in Vista, keep the line level at about 75%... Also, if yer S/C will support it, use a 24bit 96Khz record setting. You want the highest Q
you can get on the input side....
Old February 2nd, 2009, 01:36 AM     #9 (permalink)
Anime Otaku
RobRich's Avatar
Shoutcast DNAS is more about public streaming. It will probably work, but it is kind of overkill for a basic audio relay across as LAN.
VLC should do want you want with a single application. Setup VLC for stream serving on the input computer, then point VLC on the listening computer to the stream server.
Documentation:Streaming HowTo - VideoLAN Wiki
Robert Richmond | TechIMO Community Relations Director
Infinite perceptions. One reality.
FanFiction.Net - Unleash your imagination.
RobRich is online now   Reply With Quote
Ask a Tech Question (free)!
Is It Just Me? (1014)
Intel Core i7 920 heat issue help p.. (19)
Woman Convicted of Drug Fraud Joins.. (5)
I need help building a computer. 40.. (33)
Best gaming GPU for $200 or less? (17)
Nvidia GeForce gt 220 problems (21)
Trouble connecting to Apartment Int.. (16)
net use command (13)
cant find drivers (8)
Wireless coverage over 3 hotel floo.. (17)
Laptop Battery issue? (10)
Zombie Cookies Privacy Lawsuit Targ.. (6)
Rate My First Computer Build (8)
new video card- screen changes to c.. (8)
Trouble connecting to Apartment Inter.. (16)
Wireless coverage over 3 hotel floors (17)
Can't open zip files in vista??? (16)
Server 2008 "read only" (0)
120G External Drive, USB 2.0: Works o.. (2)
Help Dell Latitude D610 Power Problem.. (6)
Intel Core i7 920 heat issue help ple.. (19)
new woot (5)
Which Graphic is better? (1)
On startup my monitor clicks forever .. (1)
Cavalier Internet (12)
PC turns on, gets normal post beep bu.. (0)
D drive failure? (3)
In need of Help! (1)
DVD Recorder Set-Up (3)
System fans not working (2)
good video card around 100-200 dollar.. (3)
Linux had disk space full (3)
Minidump Help (1)
I need help building a computer. 400-.. (33)
Redirect malware won't go away (6)
laptop keys broken!!1 (3)
Audio Device on High Definition Audio Bus??? Sweeper Technical Support 1 November 29th, 2008 11:09 AM
MP3 Home Audio & Car Audio ry4n Multimedia and Audio 4 August 27th, 2005 05:01 PM
Audio over existing Network Braddini Multimedia and Audio 19 May 22nd, 2003 07:40 AM
College network Server pyro47 Networking and Internet 15 June 4th, 2002 12:21 AM
newbie needs help on going from onboard audio to pci sound card audio Xenos Multimedia and Audio 21 January 23rd, 2002 07:39 PM
TechIMO Copyright 2010 All Enthusiast, Inc.
