Sound card to enhance USB mic
Currently Active Users: 2251
Discussions: 203,412, Posts: 2,407,265, Members: 248,930
Old June 21st, 2009, 01:05 AM   Digg it!   #1 (permalink)
I have the special edition Toshiba Satellite
Processor 2.0GHz Intel Core 2 Duo T5750
Memory 4GB at 667MHz DDR2
Hard drive 300GB at 5,400rpm Chipset Intel 965GM Express
Graphics Intel GMA X3100 (integrated)
and i use a M-Audio USB Producer microphone and Adobe Audition to record my music.
so heres the problem, whenever i record vocals, theres a slight lag. Im thinking its my comp's audio card causing it and was thinking about getting a notebook sound card that goes into the EX54 slot to fix the problem but then i realized, the mic connects via USB and the card only has a speaker and mic jack, not a usb. so if i got the card, would it still fix my problem even though the mic is still connected to usb?
Kphu is offline   Reply With Quote
Old June 22nd, 2009, 02:53 PM     #2 (permalink)
anyone?
Old June 27th, 2009, 04:27 AM     #3 (permalink)
bigBonehead's Avatar
Ah.... you do realize that a USB Mic bypasses yer Sound Card.... right?
What yer experiencing is called Latency. Google is my friend.
Wisdom comes with age, but sometimes age comes alone...
bigBonehead is offline   Reply With Quote
Old June 27th, 2009, 09:17 PM     #4 (permalink)
and google hasnt come up with any answers. thats why i came here for an answer. I know it's latency, im trying to find a solution to have ZERO latency
Old June 27th, 2009, 10:02 PM     #5 (permalink)
It's the cheese guy! ¬_¬;
paul9's Avatar
Send a message via MSN to paul9 Send a message via Yahoo to paul9
Try a cheap mic to be certain, but if it is a "normal" type soundcard, I think it would cut out the lag you are getting on the USB mic.
Otherwise, good mixing software should have timing functions to re-synchronise your audio.
paul9 is offline   Reply With Quote
Old July 1st, 2009, 01:12 AM     #6 (permalink)
i use adobe audition but i cant figure out the exact time delay and i dont know how to to adjust the timing stuff. ill look it up. my usb mic has a setting thing where i can adjust latency, ranges from 128-4096. it says to set it low to lower latency. i have it on 128 and still have lag.
Old August 6th, 2009, 04:19 AM     #7 (permalink)
First of all... it's technically impossible to get zero latency.
Here's a tool that will tell you what your latency is: DPC Latency Checker (from Google)
Next, from Google: ASIO4ALL - Universal ASIO Driver A universal latency reducer for WDM based computers and Sound apps.
Google is my friend...
PureAudio USB-SA Sound Card Review RobRich Tech News Discussion 0 October 15th, 2008 04:39 PM
Sigmatel sound card and a mic makkurokurosuke Multimedia and Audio 8 April 20th, 2008 09:40 PM
Have a problem with either the sound card or mic. Armadel Multimedia and Audio 3 September 29th, 2003 06:28 PM
What tweaker do you use to enhance your GeForce Card? radio1_mike Graphics Cards and Displays 16 June 10th, 2002 08:46 AM
Sound card & USB speakers kakyoin Multimedia and Audio 11 April 23rd, 2002 03:11 PM
Is It Just Me? (3690)
Superbowl commercials (The green po.. (10)
New PC Heavy Gaming Rig (7)
Need for Speed Shift (7)
[F@H Chat]2/6/10 New thread for ya'.. (19)
I want to buid a pc with this case (14)
Motherboards with 2 PCIE x16 slots (8)
Graphene transistors promise 100GHz.. (7)
Animated GIFs don't animate? (13)
hunting for new graphics card (9)
Upgrading (5)
Upgrading Video (28)
Cl4 vs. Cl5 Memory (11)
RAM Frequency (6)
GPU upgrade from 8600 GT (4)
nVIDIA GTX 260 vs ATI 5770 (2)
120mm fan on top of case??? (12)
Is my hard drive going bad? Please h.. (2)
[F@H Chat]2/6/10 New thread for ya' s.. (19)
rsync over passwordless ssh in a cron.. (4)
HD5870 Question (15)
Wii at buy.com for $374 - Carnival Sm.. (7)
should i upgrade whole pc or just vid.. (1)
One dumb nube and a cisco 3550 (0)
Deleted email addy keeps bouncing bac.. (1)
Laptop - HDTV Connection Using HDMI C.. (1)
Video Format Total Solution: How to C.. (0)
How Good is This $450 MSI Laptop? (2)
wireless connectivity (0)
My 9400GT's fan is screwy (2)
Graphene transistors promise 100GHz s.. (7)
SpeedFan Temp Monitor Help (1)
Question about multiple monitors (3)
I bet you can't fix Bios! (4)
HP Pavillion dv1000 with Windows Xp w.. (1)
Initializine a SATA drrive (1)
disappearing icons *different problem.. (1)
