Power wont turn on
Currently Active Users: 1616
Discussions: 200,925, Posts: 2,379,127, Members: 246,291
Old June 28th, 2009, 11:49 PM   Digg it!   #1 (permalink)
Power wont turn on
Ok so im not sure if I am in the right thread or not, I am new to this, but any help would be great. I got an Aiwa CX-NA555 3 disc stereo player and one of my little cousins dropped the main piece (not the speakers), it wasnt a very big drop, but a drop none-the-less and now the power wont turn on. I have opened the stereo up but honestly I have no idea what to look for. I didnt know if these contain fuses that may have busted or what. Well this is my problem and would love for some input. Thank you
blankman22 is offline   Reply With Quote
Old June 29th, 2009, 12:24 AM     #2 (permalink)
Instigator
Atomic Rooster's Avatar
Send a message via AIM to Atomic Rooster Send a message via Yahoo to Atomic Rooster
Unfortunately, you will probably need to take it to a technician to get it fixed. There really are no user serviceable parts inside.
Atomic Rooster is offline   Reply With Quote
Old June 29th, 2009, 12:29 AM     #3 (permalink)
Administrator
ScottW's Avatar
Welcome to TechIMO. It's very unlikely that you will be able to troubleshoot this yourself without a schematic, knowledge of using a multimeter to test circuit paths, and the ability to desolder and replace parts. It isn't worth it. I'd replace it, because paying someone else to fix it would likely be cost prohibitive.
Please recommend TechIMO.com to your friends and family!
ScottW is offline   Reply With Quote
WONT turn on! Bgator General Tech Discussion 16 April 27th, 2006 05:38 PM
PC wont turn on! Amileo Technical Support 10 February 10th, 2006 02:04 PM
Power Mac G4 Wont Turn On dbtechdesign Technical Support 1 March 2nd, 2005 09:49 PM
Monitor wont turn on, Computer wont boot. HELP plz. Drakarn General Tech Discussion 11 September 30th, 2004 03:26 AM
P4 wont turn on billniceguy General Tech Discussion 5 May 2nd, 2004 12:42 PM
Is It Just Me? (2865)
Obama the Muslim (14)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
