Help ID this USB - RCA/USB cable
Currently Active Users: 2155
Discussions: 200,919, Posts: 2,379,036, Members: 246,286
Old June 30th, 2009, 09:33 PM   Digg it!   #1 (permalink)
kopfjaeger's Avatar
Send a message via Yahoo to kopfjaeger
I have come into possession of what appears to be a video to computer cable.
On one end is a standard USB type A connector, but on the other end are the following:
1 - RCA Video (yellow)
1 - RCA Sound (white)
and one very small USB-type connector.
I suspect that it might be either proprietary, as I understand Kodak and Sony have proprietary video camera to computer connectors, or it might be a micro. It is definitely not a Micro-8 connector. I am attaching image files to assist you.
This top image is not of the cable in question, but from a USB page and has an image of what appears to be similar to the USB cable connector I am asking about.
This image is of the cable itself.
The smaller of the two connectors is what is at the end of the cable in question. The larger of the two in the images which follow is a mini connector, but used for size and configuration comparison.
It's really a two-part question.
First, if this is a standard USB connector, what is the accepted name / nomenclature of the smaller of the two USB connectors?
Second, can you identify which device such a cable is intended for (e.g. make and model)
Thanks in advance.
KJ
This is supposed to be a joyous occasion -- let's not bicker over who killed who.
kopfjaeger is offline   Reply With Quote
Old June 30th, 2009, 09:53 PM     #2 (permalink)
Super Stealthy Moderator
RicheemxX's Avatar
looks like a Mini or Ultra Mini USB to RCA Cable to me say something like this
Uh IDK I'd assume it would be for just about any video device that has an ultra mini usb connection
edit: for exact names wikipedia says Mini-A, Mini-B or Micro-A, and Micro-B connectors
Linus Torvalds
RicheemxX is online now   Reply With Quote
Old June 30th, 2009, 11:06 PM     #3 (permalink)
thats the same one my phone uses, yep i use that cabe for my phone to charge it and to transfer files to and from my computer, but any more i use bluetooth...my phone is the lg dare (vx9700 from verizon)
baileyapt is offline   Reply With Quote
Old June 30th, 2009, 11:51 PM     #4 (permalink)
RicheemxX's Avatar
Yeah they'd be used for cell phones, digital cameras ect ect. Basically anything with the micro usb connections that can display video or images.
And kopfjaeger you must not spend much time on Google because dang man I found it in under a min or two.
Old June 30th, 2009, 11:55 PM     #5 (permalink)
kopfjaeger's Avatar
Hello Rich,
I do believe that is it. I managed to locate a close-up of a Micro-USB connector:
That image matches the connector on the cable in question, however, I have also seen different designs for connectors designated Micro. Naturally, I am taking into account Micro-A and Micro-B.
http://upload.wikimedia.org/wikipedi.../USB_micro.jpg
Thanks for your help.
Old July 1st, 2009, 12:04 AM     #6 (permalink)
RicheemxX's Avatar
Yeah its a mini 8 Pin male connection, I've got one sitting in my desk to connect my camera to the tv to display photos.
Old July 1st, 2009, 12:09 AM     #7 (permalink)
kopfjaeger's Avatar
Yes, well have you established exactly what the name of that connector is?
You stated Mini or Ultra mini. As I've noted there are Mini-A and Mini-B. As there are variations I am still trying to match the exact name with the image I have provided. While I appreciate what help you have given, how can you be critical when you haven't answered the question definitively?
Old July 1st, 2009, 12:12 AM     #8 (permalink)
RicheemxX's Avatar
Google it man sheesh...I don't wanna do all the work around here
Old July 1st, 2009, 12:22 AM     #9 (permalink)
kopfjaeger's Avatar
Okay, found the matching designations that go with the top most photos of various USB connectors, they are in order from Left to Right:
8-pin AGOX[citation needed]
• Mini-B plug
• Type B plug
• Type A receptacle
• Type A plug
USB to RCA Connectors? kopfjaeger Graphic Design and Digital Photography 3 January 26th, 2009 05:16 PM
RCA vs USB bandit233 Multimedia and Audio 0 September 8th, 2007 01:59 PM
Good, inexpensive RCA to USB jp22382 Multimedia and Audio 11 November 21st, 2005 08:49 AM
RCA Cable modem recognizes USB not Ethernet glover12 Networking and Internet 4 July 9th, 2004 09:29 AM
USB Mouse, USB Keyboard, 56K USB Modem w/4-Port USB Hub for $25.50 lovelydeals ResellerRatings Homepage Deals 0 July 3rd, 2002 09:23 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Is It Just Me? (2844)
Obama the Muslim (9)
Foreign voltage (8)
Print spooler problem (10)
Virus Doctor Popup? (1)
Foreign voltage (8)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
