Dumb question on movie editing - Help or Pity would rule
Currently Active Users: 2146
Discussions: 200,948, Posts: 2,379,398, Members: 246,309
Old July 8th, 2009, 05:10 AM   Digg it!   #1 (permalink)
Lightbulb
G'day
I have 2 questions probably both dumb so feel free to laugh and point.
Ok Number 1: I wanted to know how to shrink my ripped from Dvd movies that are about 4 gig to the nice small ones about 700mb that you can download everywhere.
I have dvd shrink and I have just discovered that I can change the compression and remove audio and subtitle tracks.
Number 2: After I rip them the vob files are still seperated into a few parts. How do I make them one file.
Ok so to finnish I want big movies that are split up to be one file about 700 mb.
Any help would be awesome!
briggs86 is offline   Reply With Quote
Old July 8th, 2009, 11:59 AM     #2 (permalink)
osprey4's Avatar
Hi, Briggs:
Welcome to TechIMO.
Even Shrink is not going to squeeze a full length DVD onto a CD. You have to recode to VCD or SVCD format.
Second, there are good technical reasons for not allowing the VOB files to get much bigger than 1 GB, so don't worry about it. If you recode, the file format will be different, rendering the question moot.
Old July 8th, 2009, 04:44 PM     #3 (permalink)
Thank you for taking the time to answer. I'm putting the movies on a hard drive and i didn't want them draining all the space. I dont want to put them on discs again. So does that change the way i have to recode them?
Sorry I should have said this earlier. I'm a bit slow you see.
Cheers Briggs
Old July 8th, 2009, 07:36 PM     #4 (permalink)
osprey4's Avatar
Briggs:
If you want to squeeze a DVD movie down to 700MB, then you're going to need to recode it. But if you'll be watching on a computer monitor, SVCD should be adequate quality.
Old July 9th, 2009, 03:28 AM     #5 (permalink)
Thank you mate
movie editing software... batmeat Applications and Operating Systems 2 July 17th, 2008 05:59 PM
Movie editing dani-daniel Multimedia and Audio 0 April 1st, 2007 07:36 AM
Forum Rule Question??? f1oored IMO Community 8 April 2nd, 2004 01:09 PM
editing movie thanthuong1 General Discussion and Buyer Guidance 11 October 14th, 2003 04:05 AM
Dumb bit in a movie (Unbreakable) Lemon[H]ead IMO Community 8 November 18th, 2002 04:16 AM
Making Health Care Worse (172)
The disrespect of Obama by Russian .. (22)
Is It Just Me? (2935)
Regular Build (6)
Print spooler problem (15)
How to convert MP3's (4)
Graphics Card Upgrade Question (3)
Internet Lost (1)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
