Best Software to Rip mp3's
Currently Active Users: 1474
Discussions: 200,956, Posts: 2,379,486, Members: 246,318
Old July 20th, 2009, 01:41 PM     #11 (permalink)
Anime Otaku
RobRich's Avatar
Originally Posted by MTAtech View Post
I like ripping in a high bit-rate 256 or higher, because I output to a high-end audio system and disk space is cheap.
Then you should consider something besides such an old lossy format like MP3, and going to the next level, you probably should seriously think about encoding to a lossless format like APE, FLAC, or similar.
As for a CD ripper, CDex is popular among the open source community:
CDex | Open Source Digital Audio CD Extractor with more than 38,000,000 downloads
It supports numerous audio encoding engines.
Robert Richmond | TechIMO Community Relations Director
Infinite perceptions. One reality.
FanFiction.Net - Unleash your imagination.
RobRich is offline   Reply With Quote
Old July 20th, 2009, 01:46 PM     #12 (permalink)
Light to Counter the Dim
MTAtech's Avatar
Send a message via AIM to MTAtech Send a message via Yahoo to MTAtech
Rob,
That's a good suggestion. That link seems it has not been updated in years though.
Although it is 2007 now, there is a possibility to support these old Windows versions as long as possible.
"The Bill of Rights is my Patriot Act."
MTAtech is offline   Reply With Quote
Old July 20th, 2009, 01:53 PM     #13 (permalink)
Anime Otaku
RobRich's Avatar
Not much reason to update it, as the code base of CDex reached coding maturity years ago IMO. Just grab the latest beta release, plus an ASPI layer if required, and you should be okay.
Old July 20th, 2009, 01:57 PM     #14 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
+1 for FLAC. If you have a nice set of cans, or speakers, you can hear the difference for sure.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old July 20th, 2009, 04:15 PM     #15 (permalink)
FLAC is good, and pretty widely used, though it is something of a pain in the ass to use in wmp (IMO), though itunes does have native support for it.
Also, both wmp and itunes have their own proprietary lossless formats. Personal, I am of the ipod crowd (and I do have a mac, and a pc), so I use itunes, and it does lossless encoding, and cd burner, etc.
I mean, if you don't have an ipod or zune, maybe the other programs make sense, but I haven't used a cd in probably a few years now (I ripped all my cds to pc a while back, I do still have them collecting dust somewhere though).
Also just a cool thing on the macbooks, the audio out is not just a standard 3.5mm, but also a mini-optical, which sounds great going straight into the stereo.
Intel i7 920 @ 4.0 ghz, ASUS P6T
6gb Corsair XMS3 DDR3 1600, EVGA 275 GTX 896mb,
CM RC-690, WD Raptor 150gb, WD 2x1tb cav green.
thephilosophizer is offline   Reply With Quote
Old July 20th, 2009, 10:30 PM     #16 (permalink)
MTAtech's Avatar
I'm going to experiment with the lossless formats because I output audio through SPDIF/toslink to my audio system in another room.
Old July 21st, 2009, 07:49 AM     #17 (permalink)
Super Duper Member
pullmyfoot's Avatar
I do 320kbps for my ipod
pullmyfoot is online now   Reply With Quote
Old July 21st, 2009, 08:38 AM     #18 (permalink)
osprey4's Avatar
No one has recommended EAC? Introduction » Exact Audio Copy
Old July 21st, 2009, 09:46 AM     #19 (permalink)
MTAtech's Avatar
I read somewhere that @256 one cannot tell the difference. Obviously, 320 would be a step beyond that. However, the suggestions about lossless are intriguing.
It's worth a try.
Old July 25th, 2009, 09:13 AM     #20 (permalink)
MTAtech's Avatar
Originally Posted by RobRich View Post
Then you should consider something besides such an old lossy format as MP3, and going to the next level, you probably should seriously think about encoding to a lossless format like APE, FLAC, or similar.
I think that those formats aren't support by iPods, and we have 4 of them here.
DVD rip software Prince Lalijama Storage Related 2 September 1st, 2007 07:46 AM
What Software Apps. do you use to play Mp3's? filipino Applications and Operating Systems 13 April 27th, 2005 04:50 PM
Managing MP3's Software Wanted DanGrease General Tech Discussion 4 February 25th, 2004 03:57 AM
Software to combine mp3's??? Martoch Multimedia and Audio 9 October 25th, 2003 11:55 AM
Software to check MP3's for glitches? crazyray Multimedia and Audio 3 May 9th, 2002 05:21 AM
Is It Just Me? (2943)
Print spooler problem (15)
Some methods to retrieve lost Windows.. (0)
lost Windows user name and password (13)
whats the fastest dvd ripper? (13)
How to Convert Blu Ray Disc Movie to .. (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
