Audio FX Pro 5.1 by Ben Heck need help
Currently Active Users: 1483
Discussions: 200,931, Posts: 2,379,162, Members: 246,297
Old July 24th, 2009, 01:32 AM   Digg it!   #1 (permalink)
Ok I did some research and decided on the Audio FX Pro 5.1. Managed to find a usb port that did not reverb all over the place, and the sound was well definitely better then my jbl speakers. Nice overall sound. Yet there is one problem. I can not get the mic to work, specifically in Lord of the Rings Online. I tried everything, even contacted tech support at eDimensional 3D Glasses and Innovative PC Gaming Accessories, which was useless, they just parroted their lame FAQ which had no correlation to my problem.
So maybe someone out there has this headset? The game? Or know some settings I need to adjust to make things work? I would hate to think that the headset is defective. There was at least one point during the test I heard it work, then nothing.
magealita is offline   Reply With Quote
Big Ben Dude111 IMO Community 5 March 6th, 2009 12:09 AM
IP35 Pro HD vs. AC97 audio bill1971 Motherboards 0 August 24th, 2008 01:29 PM
clean install from windows me to xp pro no audio controller bassgirl Technical Support 1 July 28th, 2007 10:45 PM
Leadtek Winfast K7NCR18D Pro Audio Alarm LUCKYDAVE Motherboards 0 January 7th, 2005 02:57 PM
XP Pro Audio Randall_Clark63 Applications and Operating Systems 2 September 16th, 2003 08:38 PM
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
