Low Volume in Zoom Player, Normal in VLC & WMP11
Currently Active Users: 2272
Discussions: 200,944, Posts: 2,379,345, Members: 246,306
Old July 27th, 2009, 03:07 AM   Digg it!   #1 (permalink)
I'm really at a loss about a sound problem that developed about two weeks ago. Some* downloaded videos are playing in Zoom Player 6 and 7 at a very low volume - or much lower volume than in VLC and WMP11. However, most music and TV downloads play at normal volume. Volume slide at max makes little difference. To give some examples, in checking four films and videos where this is a problem, two are AC-3 and two are MPEG-3 or MPEG (MP3) audio. I've installed codecs and AC-3 Filter for all of these, without any change. I posted this at Zoom Player's forum, but haven't gotten a response in two weeks. So, I'll try here. Any ideas about why this might be happening? Gnerally, I prefer Zoom Player for most videos. Thanks.
genegold is offline   Reply With Quote
Old September 23rd, 2009, 03:28 PM     #2 (permalink)
Smile
Hi,
+1
a+, =)
-=Finiderire=-
Finiderire is offline   Reply With Quote
Old September 23rd, 2009, 04:13 PM     #3 (permalink)
I forget all I did to improve the situation, but for sure one step was setting MPEG audio (MP3) to AC3 in Zoom Player.
Old September 24th, 2009, 05:22 PM     #4 (permalink)
Smile
Hi,
Thank you for answering. I do not see where to set MPEG audio (MP3) to AC3 in Zoom Player. But I have found another solution to the issue : pressing Q in Zoom Player and enable the Equalizer, then I dragged up each volume control.
a+, =)
-=Finiderire=-
Configuration :
Zoom Player v5.50 Beta 1
Old September 24th, 2009, 05:37 PM     #5 (permalink)
I wrote down somewhere that I had, but don't see where I did it now. I'll let you know if I figure it out. Have you installed AC3 Filter? The only disadvantage to the Equalizer fix is that the default settings are probably 100% volume, and anything above that will be distorted.
Btw, there's a nice little utility called Mediainfo - MediaInfo - that allows seeing the video and audio format quickly by running the mouse over the file.
Afterthought: go into AC3 Filter config and set MPEG to play with it. I hadn't done that before, but will check how it works out.
VLC media player 1.0.0 no1_vern Multimedia and Audio 2 July 12th, 2009 07:30 PM
VLC 0.9.9 media player repeat default waynezo Applications and Operating Systems 2 May 27th, 2009 09:50 AM
Any player (vlc, movieplayer etc.) shuts down, can`t play thorinator Linux and Unix 2 December 21st, 2008 11:44 AM
Volume drop on close WMP11 reiss Applications and Operating Systems 2 March 1st, 2007 11:55 AM
VLC Media Player 0.7.2 filipino Applications and Operating Systems 0 May 26th, 2004 01:31 AM
Making Health Care Worse (163)
The disrespect of Obama by Russian .. (17)
Is It Just Me? (2919)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
How to convert MP3's (2)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
