WMA or FLAC?
Currently Active Users: 1883
Discussions: 200,921, Posts: 2,379,089, Members: 246,289
Old October 15th, 2009, 07:17 PM   Digg it!   #1 (permalink)
WMA or FLAC?
I've decided to go with WMA Lossless instead of FLAC. My MP3 playerplayes WMA but not FLAC; in fact, I dont see a single MP3 player that does.However, I am still not sure whether to go with lossy WMA or MP3. WMA 96kbps sounds the same as an MP3 at 128kbps, but is 20% smaller.I could live with MP3 at 112kbps.Does an MP3 made from FLAC or a lossless WMA sound the same as made from WAV? It takes 2x longer though.I used CDex to rip to MP3 and WAV at the same time. However, WMA lossless is 10% smaller than using Winrar best-solid on WAVs, and it is playable. Thus, it seems it is best to rip to WMA lossless, and then to rip to MP3 from the CD again.
Gomar is offline   Reply With Quote
Old October 17th, 2009, 02:02 PM     #2 (permalink)
WMA lossless files are 0.055% (5 1/2 %) smaller than FLAC level 0,but about the same size as level 8.Does level 8 reduce sound quality? I see that kbps is lower.Could it be decompressed into the original WAV?
Old October 17th, 2009, 07:35 PM     #3 (permalink)
JohnE.'s Avatar
Send a message via ICQ to JohnE.
"Does an MP3 made from FLAC or a lossless WMA sound the same as made from WAV?" - Yes; FLAC, WMA Lossless and WAV are all "lossless" sources, except that WAV is uncompressed.
All are just "containers" for raw audio sample data, but lossless encoders pack the contents tighter and more efficiently. Think of a big, fluffy pillow, being put into a box.. it takes a certain size so that it fits snugly - that's uncompressed WAV, AIFF, etc. Now squeeze some air out of the pillow until it fits into a smaller box. Now take the pillow out of the smaller box, fluff it up a bit and it's still the same pillow - that's lossless compression.
Using our pillow analogy again - now try to pack it into a very tiny box. This time, no matter how much air we squeeze out, the box is just too small. We'll have to remove more than just air. Let's rip the seams a bit, yank out a few threads, pull out and throw away a few feathers. Hardly anyone will notice a few missing feathers. Now take the pillow out of the tiny box, fluff it up a bit and... damn, it's not the same any more, and we can't ever make it the same again because we threw away some feathers - that's lossy compression.
In both cases the pillow was "compressed", the difference being whether the compression algorithm used was "lossless" or "lossy" (pack bits more efficiently or throw some bits out, respectively).
"It takes 2x longer though" - The encoder has to decode the <lossless format> data and create a temporary WAV file "on the fly" and then encode to MP3. The whole process is quite math intensive.
"Does level 8 reduce sound quality?" - No, the encoder will just be more aggressive in it's efficient packing scheme than at lower settings.
JohnE. is offline   Reply With Quote
Looking for a portable player that supports FLAC audio ~~Maverick~~ Multimedia and Audio 0 September 4th, 2009 03:03 PM
Putting Downloaded .Flac on CD Brook77 Technical Support 2 October 18th, 2007 04:40 PM
converting .flac files to mp3? jpiermarini Multimedia and Audio 3 July 9th, 2005 04:26 PM
Help with .WMA fretome Multimedia and Audio 5 March 18th, 2005 11:16 PM
CD ripper with FLAC encoder [Neo770] Multimedia and Audio 7 March 4th, 2004 12:12 AM
Is It Just Me? (2854)
Obama the Muslim (13)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
